![]() | Home > My Range Rover > New to me UK RR Vogue SE (2012) - Some questions too :) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4346 ![]() ![]() ![]() |
You can look up any fault code in the workshop manual which is downloadable from the Wiki page Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
tezza Member Since: 22 Jul 2021 Location: Gloucestershire Posts: 78 ![]() ![]() ![]() |
I have those from the diags
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
I’d just drill a hole through the filter.... definitely can’t be that then..... No issues from mine after doing it.
Agreed. Drill a small hole all the way through the sintered brass valve after removing it off the compressor |
I think you’ve pretty much done all you can regarding an easy fix you can do then.
Yup cheers for the suggestion. I wonder if I should replace that silencer before taking it to the dealer since I've drilled a hole in it but I am kinda confused on this. I see this part https://www.lrparts.net/rqv500040-air-susp...-2012.html and also https://www.lrparts.net/lr025940-silencer-...rover.html And for this one https://www.brit-car.co.uk/product.php/166...over_vogue it looks like someone has already taken a drill to it. |
I wouldn’t bother replacing it. It’s sorted a potential issue and I doubt they will know it’s not been like that for years. Having a hole in it will not cause any issues.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1405 ![]() ![]() |
Try it without the filter |
