![]() | Home > Technical (L322) > l322 Alignment (Kwit Fit) Advice Please |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
See attached
Unfortunately 2003 has no tight tolerance mode :-/ but was put on ramp, engine off and on to let it self adjust. rolled back and forward and door left open so the suspension would not self adjust. suspension locked into normal ride height.
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
I would guess that you might get some scrubbing of the rear tyre on that side as it is clearly outside of tolerance, although the front appears to be OK. How did it drive afterwards, has the pulling to one side gone now? 2011 TDV8 Vogue SE |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
www.alignmycar.co.uk is a good place to start Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Seems to drive fine now, toe was showing on screen large out spec which they did fix and seems to resolved main issue with steering pulling to one side, and camber on front from research there right need a tool to do.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
Camber is easy to adjust on both front and rears, but I would definitely check your rear suspension bushes top an lower before perusing further, they do have a tendency to wear which would put you suspension geometry out.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 672 ![]() ![]() |
Our L322 was done by a local place, it didn’t feel right at all afterwards. So we had it done by a specialist that the local Porsche garage apparently use and it was night and day.. it wasn’t cheap £90ish but it make all the difference.
