Home > My Range Rover > Back with another Supercharged
Page 15 of 58 <123 ... 141516 ... 565758>
dhallworth
That’s true!
Rob emailed earlier saying the transfer box had left Duckworth’s today so this evening I decided to sort out the headlights. Well, one of them! They were pretty grotty before.
Forgot to get a picture of the drivers side before so here’s the passengers as they both looked the same!
1st step was wet sanding with 800 grit discs.
2nd step was wet sanding with 1000 grit discs.
3rd step was 1500 grit which didn’t make much difference to the appearance so I didn’t picture it.
This was the 4th step wet sanding them with 3000 grit discs.
Finally I used a cutting polish to remove the fine scratches from the wet sanding.
Finished:
I didn’t bolt it back into the car as I still need to apply the UV Protective coating on them so I just positioned it and the grill in loosely to get a comparison shot.
It’s not perfect but it’s infinitely better then it was and considering it was my first time wet sanding headlights I’m quite happy with the results for now. Once I’ve got the mechanicals all sorted I’m pondering the idea of a 2012 facelift so I’m more then happy with these for now Smile
Post #602702 3rd Aug 2021 7:39pm
GGDR
Give it another polish David then hit it with some kind of lacquer to protect from UV.
. Cheers, Greg
Post #602707 3rd Aug 2021 8:25pm
dhallworth
I’m thinking of doing the whole process again just to see if it’ll come up any sharper but there’s a big improvement already from what it started with.
I’ve got a tin of UV protection spray that I’ll give them a couple of coats of before they see daylight again Smile
Post #602722 3rd Aug 2021 9:07pm
They look good, sometimes it's the inside of the lens suffering from UV damage, have a close look before polishing again... Thumbs Up Pete
-Click here for Thread-
Post #602741 3rd Aug 2021 10:18pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Looks a decent job you done mate
Post #602742 3rd Aug 2021 10:20pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I started doing mine today, so wanted to ask what lacquer does any one recommend? Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #602755 4th Aug 2021 2:05am
Any with UV protection... Thumbs Up
https://www.ebay.co.uk/itm/321540405373?ha...xyaURTf0fu Pete
Post #602759 4th Aug 2021 8:32am
dhallworth
I bought this kit to do mine:
https://www.amazon.co.uk/gp/product/B075KF...d-M5R_52QE
It includes the sanding pads, polishing pad and compound and finally a UV protection spray.
Post #602787 4th Aug 2021 11:40am
dhallworth
TNT turned up with a delivery today… unfortunately nobody was home Big Cry
They’ve said they’ll be back tomorrow with the transfer box so I won’t be going anywhere tomorrow and will be working with my laptop right by the front door as I’m not missing this delivery Laughing
Hopefully we’re on the home straight again now.
Post #602949 5th Aug 2021 10:13pm
dhallworth
A delivery arrived today Very Happy
Opening parcels is fun as they always contain shiny things!
I’ve refitted these several times now so it doesn’t take that long. I managed to get it refitted on my own other then the exhaust as that’s one piece from front to back and weighs a ton! The new transfer box is fitted, filled with oil, calibrated and has drive so that’s good.
I noticed previously that someone had snapped the stud in the offside manifold and had fitted a nut and bolt so this time I thought I’d sort it properly. First up was drilling it out.
Second step was to tap it to take an M8 helicoil.
Third step was to insert the helicoil
Fourth step saw the new stud correctly back in it’s place.
I put the UV protection spray on the headlights too so the car is now finished and ready to come out of the workshop tomorrow. The lights aren’t perfect but they’re a lot better then they were.
I was filthy when I’d finished tonight and there were other cars in the workshop so mine is waiting till tomorrow to be test driven.
Quite nervous tonight… after all this work (and cost) I’m praying that the bearing whine is now gone!
Post #603065 7th Aug 2021 12:22am
Good job and good luck, fingers crossed it stays off the ramp for a while... Thumbs Up Pete
Post #603070 7th Aug 2021 8:04am
dhallworth
I’ve had the Range Rover for a run this afternoon and am pleased to report the whine has gone and the car is changing gear beautifully. There’s still a feint grumble from the front diff but it’s not bad so it can wait for a while. The oil I put in it in January is still clean so it can’t be doing much damage to itself and Cheryl can hardly hear it so it’s probably just me being OTT.
Anyway, long story short, I have a working Range Rover again Very Happy
Post #603118 7th Aug 2021 5:59pm
A long bumpy road but pleased to hear you got there...
Now go and enjoy... Thumbs Up Pete
Post #603121 7th Aug 2021 6:07pm
Merchy
Glad to see you got there, this is a very interesting and informative thread, an example to us all. Hat's off to your superb spanner skills Sir. Bow down Thumbs Up
Post #603123 7th Aug 2021 6:26pm
bigbo
Agreed a great thread, really enjoyed following despite the frustrations along the way.
Fingers crossed that that's the end of the woes.
Lots of info for all of us, so thanks. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #603148 7th Aug 2021 9:55pm
