Home > Technical (L322) > Tope hose collapsed or by design ? TDV8 3.6
Klunk
Hi,
Looking my engine over today and noticed one of the top hoses looked like it was collapsed .
I have circled it in the picture.
The ‘collapsed’ bit is underneath and i struggled to get a pic of it.
TIA
Post #602615 2nd Aug 2021 8:25pm
kevinp
Undo your expansion cap and see if the hose returns to it's proper shape. If it does try a new cap and bleed all the air out.
Post #602618 2nd Aug 2021 8:31pm
Klunk
Re: Tope hose collapsed or by design ? TDV8 3.6
Klunk wrote:
Hi,
TIA
Thanks I’ll try that tomorrow
Post #602619 2nd Aug 2021 8:36pm
Klunk
Is there a specific bleed process?
Post #602620 2nd Aug 2021 8:40pm
Klunk
Took off the expansion cap and nothing, no in rush of air, nor did the top hose open up.
What are other’s 3.6 TDV8 top hoses like?
Post #602733 3rd Aug 2021 9:45pm
If refitted by a lazy mechanic they can be twisted slightly, this has the effect of partially collapsing the hose, move the continuous pressure hose clamp up the hose so you can twist the hose and see if that helps, do it when cold and not under pressure and any coolant loss should be minimal... Thumbs Up Pete
Post #602744 3rd Aug 2021 10:35pm
GraemeS
Australia
Are you referring to the protective sleeve over the hose not being a snug fit or are you seeing that the hose inside it is collapsing?
Post #602754 4th Aug 2021 1:07am
Klunk
The hose itself on the bottom
Post #602767 4th Aug 2021 9:51am
ur20v
A Trap
There are marks on the hose, plastic fitting and clip. All need to be aligned correctly or you run into issues like rubbing and collapsing
Post #602769 4th Aug 2021 9:55am
Klunk
UPDATE
Well the hose split a mile from home, got a low coolant warning but the temp didn’t rise.
Had it recovered ( i don’t take chances with things like this)
Cost 110 quid to replace - it split at the bottom of the hose.
All good now.
Post #603401 10th Aug 2021 7:28pm
Sorted, check the others, they may not be far behind... Thumbs Up Pete
Post #603411 10th Aug 2021 9:39pm
Klunk
Yep, when he said it would be a 100 quid ish to fix - i said exactly that,
The others are good.
Post #603420 10th Aug 2021 10:09pm
