Home > Technical (L322) > Help needed identifying cylinder ..
steptoe
2003 V8 4.4 Petrol engine (BMW).
IId is showing injector fault on cylinder 5... Anyone know which identifies as cylinder 5 on the engine using the IID diagnostic tool ?
Looked through the user manual but not having any luck finding cylinder numbering/order.
many thanks..
Post #602390 31st Jul 2021 2:00pm
 Pete
Post #602397 31st Jul 2021 4:11pm
steptoe
Thanks for that, much appreciated.
My query was more regarding the Gap IID tool using the same identification/numbering of the cylinders as Range Rover/BMW.
I've third party diagnostics for BMW motorcycles and they use a different numbering sequence, i.e. they reference number ! cylinder as number 2, and that's on the flat twins, the multicylinders are also different between the manufacturers schematics and diagnostic companies Mr. Green
Post #602571 2nd Aug 2021 12:19pm
Never heard of them using anything other than the numbering specified by JLR...
Email Gap if you are not sure... Pete
Post #602578 2nd Aug 2021 1:04pm
dingg1
2007 Range Rover Vogue SE 4.2 SC V8 Stornoway Grey
Just pull a coil pack off one and see which cylinder goes into fault on the tool?
Post #602583 2nd Aug 2021 1:25pm
steptoe
All done. Fuel rail and injectors removed and faulty injector replaced.
The LPG system wasn't as obstructive as i thought it would be.
Post #603474 11th Aug 2021 1:06pm
