![]() | Home > Technical (L322) > Intermittent Starting Issue - L322 4.4 v8 Any Ideas ? |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 376 ![]() ![]() ![]() |
Starter relay is part of the starter motor it is normally the live terminal inside the relay that gets burnt. This leads to the clicking as the ignition key activates the solenoid but the power connection is not made so starter motor does not activate. At first it will normally work after several attempts and may work for a short period before failing again. Using a booster pack increases the voltage which helps overcome the burnt terminal and gives enough oomph to jump over and activate the starter. Only long term solution is to replace the starter 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
What Graeme said. Long term solution is to keep the electrics happy in the path, from JBB > BCU/JBC > JBE. I think the culprit might be the resistance developed over time causing supply drop. This is the case for me. Starter solenoid could be a side effect due to poor contact over time. Now with all the electrical clean, my car feels like it starts differently ..assured. ..even with low battery voltage. Note: I may still have a drain someplace that i am chasing, I going from corner to corner stripping modules etc. I have also cleaned all the blade /mega fuses. BTW JBC is the BCU 2010~12 cars, where car keeps master CCF etc ..keep is happy with clean juice ![]() New Toy: Unimog U1550L/37 New : G350D |
Finally made my way into the engine/starter circuit, removed and cleaned trigger wire form starter relay to starter seem ok. Can do with thicker wire. Following "interesting observation made" Voltage drop to the starter relay coil from ECM it self .5v~.75v. This will still work when the battery is charged, but a weaker battery will result in this relay staying open and "no crank". Appreciate ideas to nail down the voltage drop/resistance pls ![]() New Toy: Unimog U1550L/37 New : G350D |
Stop swapping starters folks, I think the issue is with the starter relay which is badly pitted and burnt over time. What
