![]() | Home > Maintenance & Mods (L405) > Roof rails for L405 |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
Yes apart from you would need a spare set of finishing strips to replace the drilled ones. I have greased all my bolts incase I ever decide to remove them |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1422 ![]() ![]() |
Marsie
Also what's the clearance if the sun roof was opened? 2018 SE SDV8 4.4 Byron Blue |
LT Member Since: 13 Mar 2017 Location: South West Posts: 416 ![]() ![]() ![]() |
![]() Seeing as I already have a large roof box, this could be the solution if in the future the need for extra space arises. |
these bars https://www.ebay.co.uk/itm/383762278112?_t...%7Ciid%3A1 not got the crossbars yet but will fit them and check clearance when they arrive.I think the height of the rails plus the height of the cross bars it should be fine.Even if its close it won't be an issue as I only need to fit my roof box when we go on holiday (October and December) so I don't think I will need the roof open ![]() 2014 Range Rover vogue se 4.4sdv8 Loire Blue 1992 Range Rover Vogue LSE 4.2 Ardennes green |
Thats the reason I went for roof bars, I already have a large Thule box ![]() 2014 Range Rover vogue se 4.4sdv8 Loire Blue 1992 Range Rover Vogue LSE 4.2 Ardennes green |
Ignore my last post, the roof bars in the above post have arrived but are wrong (one is 108cm long which is right but the other is 105cm long which is too short to reach)
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 303 ![]() ![]() ![]() |
Just to update I finally got around to fitting the roof rails today. Took about an hour for the first side and about 40 mins for the second side, at a steady pace. Overall, I'm very happy to finally be able to collect my Oztent from my mate's house |
@Marsie, did you get to the bottom of this? Just gone to buy an identical pair and they still say on the photos that one is 108cm and the other (front) is 105cm? https://www.ebay.co.uk/itm/383762278112 EDIT: I heard back from this seller, they say the bars don't fit the L405! Despite being advertised for an L405! I had queried that one of the photos showed that they are not compatible with the type of 'open' roof rails we have. This is regardless of the length issue. I have walked away and bought a second hand pair of genuine cross bars instead. FFRR SDV8 Autobiography |
