Home > Maintenance & Mods (L405) > Coolant Leak
RR1234
2014 Range Rover Autobiography SDV8 Luxor
Coolant Leak
RR 2014, 4.4
I appear to have a Coolant leak. Nothing drastic but "warning Coolant Level Low" appearing every (say) few weeks. The leak isn't obvious and may be in an inaccessible part of the engine (i.e. need someone with the proper experience and kit to sort). In the meantime, is it ok to top up the reservoir with deionised water from Halfords?
Post #589241 27th Mar 2021 3:49pm
AnotherMutley
I've got the same issue, waiting to go into the Dealers again, main culprits seem to be Thermostat Housing and/or seal, or Oil Cooler O Rings.
Can you smell coolant outside the car, at least you know then that its not somewhere behind the dash?
I'd get some Antifreeze and mix it as per the instructions, needs to be the Orange stuff.
If your handy with the spanners, get a pressure tester for around £50-60 and follow the procedure in the workshop guide (in the WIKI) to pressure test the coolant system and cap. If mine wasn't under warranty, I'd have a look myself.
Post #589245 27th Mar 2021 4:26pm
RR1234
Thanks this is really helpful. I don't smell anything and i suspect it is deeper in the engine bay. Probably a seal as you mention. I'm not gonna unleash my motor mechanic ignorance on the RR! Too expensive for me to muck around. I'll get the RR checked out by the local dealership asap and in the meantime keep the reservoir topped up.
Thanks again
Post #589251 27th Mar 2021 5:00pm
RR1234
I intended to reply sooner but got distracted by life and the onset of early dementia I guess! The issue was a leak from the oil cooler and thermostat hosing. I replaced the housing and cooler along with water pipes and gaskets etc. An eye watering £1,850 plus VAT to sort. Thankfully the problem has been solved and going a treat since.
Post #604285 20th Aug 2021 4:23pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
I saw a new cooler on Ebay yesterday for £102. Pretty pricey labour then!
Post #604298 20th Aug 2021 8:30pm
Merchy
About £2220 'all in' for fixing the water leak, by a main stealer Shocked Thud
That 'dealer experience' is the best advertisement for good LR Indy garages that I have ever seen. The dealer must have been thinking Ner Ner all the way to the bank. For that price I'd want the parts gold plated.
Post #604304 20th Aug 2021 9:54pm
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
Coolant Leak
Hi I have had a coolant leak since February. 2021 I am adding 1 litre of coolant every 500mls Had car into a reputable RR garage. They said the did pressure test for 1 hour took car on 20 mile run and still could not find it To date I have added 11 litres. I'm at loss as to what to do now
Post #608749 9th Oct 2021 7:36pm
TJH1985
We had the same thing with ours and several visits to the main dealer, passed pressure tests etc.
Turned out to be the coolant lines running to the back of the car, leak was near the rear drivers side wheel arch and was dripping into one of the shields so you never noticed it. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #608750 9th Oct 2021 7:54pm
Pat
Thanks for that I will investigate further
Post #608798 10th Oct 2021 3:42pm
CTC did a post on it a while back, there is a cheap way of fixing it iirc….
https://www.fullfatrr.com/forum/topic48938...olant+leak There is nothing that can't be fixed with a hammer😜😜
Post #608801 10th Oct 2021 4:42pm
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Oh damn.....just read this. Mines in the dealers with the same symptoms. Its under extended warranty but I can see an argument brewing whether the pipes are covered! L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone
and lots of other none LR stuff…..
Post #693982 6th Jun 2024 3:27pm
TJH1985
Extended warranty did our old one Thumbs Up
We had both issues, rear coolant pipes in the usual place and the thermostat housing both on a 2016 <40k on the clock. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #693993 6th Jun 2024 4:29pm
nambFFRR
Oh good…..fingers crossed for me then! I should find out in the next day or so…. L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #694004 6th Jun 2024 11:56pm
nambFFRR
Work has been approved and covered under the JLR Extended Warranty. Should get the car back by the end of the week👍 L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #694316 12th Jun 2024 5:03pm
