![]() | Home > Maintenance & Mods (L322) > M62 v8 timing chain and guides replacement |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 824 ![]() ![]() ![]() |
i thought i had answered this post but apparently I haven’t, thanks for your reply. I used a cheap Chinese one too and the right hand bank is out of time according to the diagnostic tool RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1033 ![]() ![]() |
Well it's been a while, 1 of the new hg failed after the rebuild so its all been stripped and done again. Just the hg this time, both of them for peace of mind with an uprated kit....heads skimmed and pressure tested all good a snapped bolt in the rear for the coolant cross over manifold was drill.out and Ali welded/plugged then redrilled and taped. I also resealed the vanos units while they were off as I didn't do it last time.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3259 ![]() ![]() ![]() |
Says video is set to Private Dave. Ned to login to see? |
Set to public, the pcv is not connected nor the air box, lpg etc so just rnuff for a start up |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8772 ![]() ![]() ![]() |
Glad you got it sorted, hopefully that's it for a while..
Fingers crossed its the last time messing with the engine. Not touched the headlining yet this has been at my mates place he has done all the work for me on his spare time.
Car drives like new after the rebuild but I'm chasing an old oil leak behind the oil filter housing connection plate.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
many years ago, i did my chain guides, at 140k drove it another 65k, till i sold the car, still purring.... but with a broken gearbox... i had no issues, apart from frostbite, as i had to do it outside during one of the beast from the east cold snaps. i changed the vanos seals, with a press tool, from usa. you dig out the seals, flick some new ones in, and then use the tool, with a pole, to crush or burr over the lips, to make then seal better. it went well.. had a minor oil leak, but sorted that out. also did a lot of other brittle parts at time, like rocker covers, valley pan cover, and water pump tubes. and also a cooler thermostat upgrade. these were superb engines in their day, but the high running temps made everything so brittle, and hard, so you got leaks galore, and overheating if not kept in check. even at over 200k, the internals looked splendid. i have a similar engine in one of my other cars, an 8 series bmw but not the vanos version. i followed the beisian systems procedure, and used all bmw parts. back in the day, the tool set was 400 quid, plus another 100 for the vanos tool. the job back then cost me about 1000 with tools, which i should have sold on, as i never used them again. i think still have the crank locking bar i made to stop the engine, so you can break the crankshaft jesus nut, with a huge pole. we didn't have battery windy guns then.
Yep this engine is pretty well sorted now and running like a dream just this historic oil leak which I'm sure is comming from the said counter sunk bolt, it's clearly in the oil way lookingvat the casting.......just wanted to see if anyone has pulled it before for reference before I do next week. |
good luck getting that plug out
Thanks Knares, at least now I know its just a plug and nothing else. If I can't get it out I'm sure I can seal it up somehow from the outside.
why not brake cleaner the front of the leak, and smear sealant over the face. -if it works, its a fix. no mechanical risk at all. |
