![]() | Home > Technical (L322) > air suspension issues |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1406 ![]() ![]() |
today the car fell to the bump stops on first setting off on a short journey
Unfortunately all I get is the slow to raise alarm then the compressor overheats, (its about 29 degrees ambient when I was working on it) I'm leaning towards a front valve block issue now, when the wheel was off, the car had went into extended mode and the bag was well inflated with no apparent leaks, it was only when it got lowered off the jack and weight was back on the bag that I got the hiss.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
My money is on the airbag.... |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 786 ![]() ![]() |
I’ve used my IID tool to depressurise a strut to change it. Could you not isolate one corner at a time to get a clue where the problem is ? |
Problem is cass, can't get the thing pumped up enough without the compressor going into over heat, I think Joe may be right, going to remove the wheel and plastic covers and see wtf is going on tomorrow, wishful thinking is the front valve block, reality is probably new air bag, but would one bad airbag deflate all corners? |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Mine was very similar, no real leak apparent when it was sat on its wheels at normal height. The leak was very prominent when raised to high though, the air bags fold over themselves with suspension travel thereby sealing the leak. I connected my workshop compressor to the system whilst testing, that resolved the overheating compressor issue. BMW i3 Electric Car
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
@dingg If your compressor is continually over heating to deal with a leak due to run time there is also the possibility that the compressor is not performing as it should due to wear thus not pumping the required airflow. Just a thought. |
Good point, I had to nurse mine back from Northern Ireland and kept resetting the error with the GAP tool. My compressor was next to useless when I'd finally fitted the new bags. New compressor sorted it but certainly overwork killed it. BMW i3 Electric Car
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
On Monday the front right airbag on mine blew. The messages I got on screen were "Suspension fault" followed by "special programmes off" . I started back home and got a message to the effect that the system would restore when it had cooled down.
Cheers guys for your thoughts , today I jacked up the car , drivers side airbag was completely deflated , managed to get it pumped up with no apparent leaks , went for a short drive and the exhaust on the compressor was popping and releasingsn air and refilling the airsprings , now I think the system was working overtime and something isnt quite right , suspect airbag appears to be ok , but immediate problem is I have a suspension fault code which wont clear and this doesnt help with trying to diagnose the leak issue as it stops me raising or lowering the car
Does this thread on Disco 3 forum help?
cheers weegie , got the car on a flat bit of ground , which is a feat in itself where I live , anyway forced a recalibration to the suspension and thats allowed me to pump up and down and indeed there aleak on the front right airbag at certain heights of suspension , will order two airbags and hopefully a mate who is currently in britain will bring them back for me.
