Home > Technical (L322) > Seat base heater motor
Tiprat
Good morning everyone, so my second post, whilst I am waiting for the tailgate to arrive for my 2008 3.6 V8 D.
I took the drivers seat out to see if I can find out why the SRS light is on, and also why the drivers seat isn't heating up. I've stripped and cleaned the inside of the seat buckle holder, so hopefully that might sort the SRS light out, (if not I shall order one from eBay.
So on to the heater motor, is there any way of testing the unit, or any spares available, to repair them, or is it simply a new unit?
Another question is there only one in the base, if so how does the seat back heat up?
Regards
Tiprat
Post #606008 9th Sep 2021 9:19am
theres a motor in the back as well,
this is from the WM,
also, you're asking about a 3.6 but your car profile says you have a 4.4??? ... - .- -.
Post #606009 9th Sep 2021 9:28am
Tiprat
Good morning Stan, thank you for your reply I've ammended the engine to TDV8.
As for the heater motor picture thank you, so do they work in tandem, or series? I only ask because the previous owner spilt a large Starbucks ove the seat base and since then the heater hasn't worked, so I figured it would only be the base one faulty.
Tiprat
Post #606010 9th Sep 2021 9:54am
you'd have to have a read of the WM for that info...the download link is in the wiki.. ... - .- -.
Post #606011 9th Sep 2021 10:25am
