Home > Maintenance & Mods (L405) > Turbo Replacement
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
Turbo Replacement
Range Rover 2013 4.4SDV8. Hi I have an oil leak from my left Turbo Garage says engine needs to come out for replacement. Any thoughts or experience with this issue
Thanks
Post #605916 8th Sep 2021 11:40am
GraemeS
Left when looking at the engine from the front of the car or standing behind looking forwards? The right turbo when looking forwards from the rear can suffer from oil migration through the wires from the oil sensor in the sump if the blocking harness hasn't been fitted. The blocking harness is applicable to all L405 and L494 SDV8 engines and all vehicles were subject to a recall but your vehicle may have been missed.
Post #605935 8th Sep 2021 1:36pm
Pat
It’s left when standing behind car
Post #605948 8th Sep 2021 3:25pm
diesel Dave
England 2015 Range Rover Autobiography SDV8 Loire Blue
That’s the secondary turbo then, they can be removed with the engine in situ I’m pretty sure, unless someone has rounded / damaged bolts ETC, that said either way they can be a Censored to get out due to room, or lack of it.
I know in the L322 you had to take the diff out to gain access, not had the pleasure yet on the L405 but they look very similar.
Just make sure all your hose clips are tight before taking the plunge.
Post #605955 8th Sep 2021 4:29pm
Pat
Sorry to be ignorant but I’m not sure what you meant by secondary turbo any chance of an explanation or point me in right direction
Thanks
Post #606045 9th Sep 2021 6:16pm
diesel Dave
Hi Pat, they have two turbo’s, a primary which is used for most driving and a secondary which only comes in when high power is required. (Above 2400 RPM under load). Very similar to a bi turbo but Called twin parallel sequential turbos for the 4.4 full fat.
The primary turbo is on the driver side and is an electronic variable vane turbo. The secondary turbo is on the passenger side and is just a no nonsense big turbo. Both can leak oil but check all the hose connections (jubilee clips) as if they’re not tight they can leak, and a little bit of oil looks a lot when spread around in the wind.
I would also get a second opinion before taking the engine out as it’s a huge job on one of these.
Post #606056 9th Sep 2021 8:48pm
Pat
Thanks Diesel Dave that is a great explanation I will have a look for any leaking joints before committing to renewing turbo
Post #606058 9th Sep 2021 9:24pm
mjdronfield
So how does the turbo set up differ from the 4.4 TDV8 in the L322 and the SDV8 in the L405?
Often wondered….. I know it’s not the question the threads about…. Just curious….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #606060 9th Sep 2021 9:40pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Same.
Post #606061 9th Sep 2021 9:55pm
As DD said, but to add for simple clarity. The 3.6 had a turbo per bank and both worked equally with any amount of throttle input… The 4.4 both in TDV8 & SDV8 guise worked like train carriages ie one behind the other… First one is highly refined and does all the lower rev work (and massively reduces turbo lag) and the secondary is a wacking great turbo that’s just there for “power”…
Post #606072 10th Sep 2021 9:50am
