Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal
Page 4 of 17 <123 45 ... 151617>
kokamagi
Estonia 2011 Range Rover Autobiography TDV8 Santorini Black
No they're not, because they're forced to reduce emissions in cars by governments. And these systems successfully fulfill this purpose. Unfortunately inherently these systems are bad for engine health and longevity, as well as for fuel economy.
So motor manufacturing industry for sure wouldn't apply those systems if they would like to offer more reliable and economic agregates. It is just that they are in a forced situation.
You just have to see the bigger picture here.
Don't want to argue about politics or phylosophy actually.
I'm more interested in any actual technical advice that has real value in this topic.
Post #606084 10th Sep 2021 11:31am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Just to add my own two penn'orth, leave the EGR and DPF alone on the 4.4.4TDV8.
That is all.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #606143 10th Sep 2021 10:21pm
kokamagi
RRDunc can you explain? Bad experiences or just a guess?
Post #606190 11th Sep 2021 9:20am
RRDunc
The DPF regen needs the EGR to be able to get up to temperature to regen properly.
There's the additional complication that DPF removal is an MoT fail in the UK.
Post #606462 15th Sep 2021 11:00am
daveturbo
EGR DPF Delete 2011 4.4 TDV8.
Since i have had a Standard Land Rover Map reinstalled ,EGR Blank Removed, Full Exhaust from a Friend, mine is Running Amazing. Do not have a Remap Fitted its not worth it. Mercedes AMG w207
E class Cabriolet
Overfinch L322 4.4 tdv8
1987 sierra rs cosworth 3 door white.
1985 escort rs turbo series one.
1992 sierra sapphire 4x4 cosworth red
1993 sierra sapphire cosworth 4x4 silver
1993 sierra sapphire cosworth 4x4 white
1995 ducati 916sp.
Post #606481 15th Sep 2021 3:11pm
But a remap is something quite different DT..... Neutral
Post #606512 15th Sep 2021 8:45pm
daveturbo
Cats
Not unless you drove one with a remap , Censored to say the least. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #606599 16th Sep 2021 7:32pm
DrRob
Lots of Censored remaps out there.
Only ever use Bell Auto Services or Alive Tuning would be my advice Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #606601 16th Sep 2021 7:42pm
mjdronfield
Or JE Engineering…. Only 3 I’d use.
JE did my TD6, Alive Tuning (when they were TD5 Alive) did my Disco 2.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #606611 16th Sep 2021 8:23pm
Re: Cats
Mines remapped sir… Ubbelievably good now! All the little low spots and lagged spots have all gone! MUCH MUCH better sir…
Post #606620 16th Sep 2021 9:30pm
daveturbo
Remap
Is yours a 4.4 tdv8 Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #606622 16th Sep 2021 10:15pm
RRDunc
I'd add Gareth Ell at Empire Tuning. He used to work at J E Engineering before he set up Empire.
Post #606625 16th Sep 2021 10:51pm
Re: Remap
daveturbo wrote:
Is yours a 4.4 tdv8
Yes sir... This is my 4th 4.4SDV8 and everyone has been mapped Thumbs Up
Post #606628 16th Sep 2021 11:25pm
kokamagi
Dunc.
Wrong... EGR is the one that lowers exhaust temperature, hence producing the soot that clogs the DPF. For DPF regen increased temperature is indeed needed and this is achieved by shutting off EGR and introducing additional fuel to the exhaust.
You wouldn't fail MoT, if You'd leave an empty shell of DPF in there and write it out of ECU. Of course, you must delete EGR also, because otherwise, you'd fail because of the soot.
Post #606973 21st Sep 2021 12:49pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Re: Remap
WRONG...
 BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #606980 21st Sep 2021 2:58pm
