![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal |
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
Just to add my own two penn'orth, leave the EGR and DPF alone on the 4.4.4TDV8.
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 ![]() ![]() ![]() |
RRDunc can you explain? Bad experiences or just a guess? |
The DPF regen needs the EGR to be able to get up to temperature to regen properly.
daveturbo Member Since: 11 Nov 2012 Location: county durham Posts: 107 ![]() ![]() ![]() |
Since i have had a Standard Land Rover Map reinstalled ,EGR Blank Removed, Full Exhaust from a Friend, mine is Running Amazing. Do not have a Remap Fitted its not worth it. Mercedes AMG w207
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16344 ![]() ![]() ![]() |
But a remap is something quite different DT..... |
Not unless you drove one with a remap , |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Lots of |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7931 ![]() ![]() ![]() |
Or JE Engineering…. Only 3 I’d use.
Mines remapped sir… Ubbelievably good now! All the little low spots and lagged spots have all gone! MUCH MUCH better sir… |
Is yours a 4.4 tdv8 Mercedes AMG w207
I'd add Gareth Ell at Empire Tuning. He used to work at J E Engineering before he set up Empire. Dunc. The life you have is the only one you'll get; make the most of it. --------‐--‐-----------------‐------------------‐--------------------------------------------------- 2012 4.4 TDV8 L322 Autobiography 2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!) |
Yes sir... This is my 4th 4.4SDV8 and everyone has been mapped ![]() |
Wrong... EGR is the one that lowers exhaust temperature, hence producing the soot that clogs the DPF. For DPF regen increased temperature is indeed needed and this is achieved by shutting off EGR and introducing additional fuel to the exhaust. You wouldn't fail MoT, if You'd leave an empty shell of DPF in there and write it out of ECU. Of course, you must delete EGR also, because otherwise, you'd fail because of the soot. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
WRONG... ![]() BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
