![]() | Home > In Car Electronics (L322) > Voice Recognition not working following windscreen change |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
are you pressing the correct button?
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 ![]() ![]() ![]() |
I am pretty sure I am.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
Where is the microphone ??
the 'little face' one is the correct button for voice and a short press gets a beep..why this is trying to make a call is weird...
Microphone is in the head lining, they did have to remove the front of the headlining when they did the windscreen. I have checked the microphone settings on one of the hidden menus and it doesn’t look right, I have to shout for it to hear and register my voice. I have decided to get Autoglass back to check position of microphone and ensure all connections were done correctly. |
No beep when pressed. I have pulled some fuses and done a battery reset but to no avail. I am going to get Autoglass back to check the connections. |
I have fixed it!
ah, you never told us about the disc....
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
How does the satnav disc control speech recognition? Ron B. VK2OTC
Must be some software code that enables it.
I noticed recently that voice recognition on my 2003 L322 wasn’t working. Faultmate indicates the module is faulty but I wonder. It’s not something I use so I wonder if it stopped when I removed the 2G/GSM* phone and did the ULF conversion.
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
I remember when I had issues with mine & thought it was the steering wheel controls. New Sat nave unit cured the problem.
