Home > In Car Electronics (L322) > 06 L322 - How to stream from iphone? |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2970 |
I use a male to male 3.5mm audio cable connected to the rear aux in socket that hides under the flap on the rear of the cubby box.
16th Sep 2021 12:06am |
Grayson Welly Member Since: 05 Sep 2021 Location: SW20 Posts: 95 |
This is an incredibly helpful and well explained response. Thank you for this and the links.
17th Sep 2021 2:57pm |
That's quite interesting, I hadn't seen that before. I don't like that big charging socket sticking out of the rear socket though. If I was fitting that I'd try and get power to that device without having it visible like that as I like subtle.
17th Sep 2021 3:11pm |
The video is a little amateurish and doesn't give an image of the final product, unfortunately.
17th Sep 2021 3:15pm |
This is a great tip for streaming bluetooth.
19th Sep 2021 9:39pm |
Archieatkins Member Since: 15 Oct 2019 Location: Birmingham Posts: 125 |
I got really excited by this when I saw the thumbnail and then I watched the video and nope - looks far too messy for me. |
20th Sep 2021 4:51pm |
Which one Archie? --------
20th Sep 2021 6:45pm |
The luxury Land Rover one. I have the Bluetooth dongle into aux solution at the moment but thought this might be some sort of replacement port unit from the picture |
20th Sep 2021 8:35pm |
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 |
I use an Amazon Echo Auto plugged into the Aux port in the rear. Very pleased with it. |
23rd Sep 2021 4:25pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Surrey Posts: 182 |
Can you play music from your phone on the echo? 2007 TDV8 Vogue SE
26th Sep 2021 1:38pm |
Yes.
26th Sep 2021 1:41pm |
Brilliant, I did not even consider this, I’ve got a little Bluetooth dongle, but I want something better, does it connect as soon as you get in or do you have to manually connect every time? 2007 TDV8 Vogue SE
26th Sep 2021 1:45pm |
Yes, pairs automatically.
26th Sep 2021 2:30pm |
Absolutely, thanks for the suggestion, I’ll try it out I think 2007 TDV8 Vogue SE
26th Sep 2021 6:48pm |
