Home > Maintenance & Mods (L322) > Front Air Strut Replacement
Page 2 of 3 <123>
Weegie
Thumbs Up John
GAP iiD BT-Sold
Post #606041 9th Sep 2021 5:20pm
dingg1
Keep us updated weegie
I'm going to be doing the same soon and just contemplating handing it over to someone local to do it if you have a struggle with it Confused
Post #606049 9th Sep 2021 7:30pm
Weegie
I won't be doing it myself, i did both fronts on the Td6 but since then I have had a major operation and can't lift weights or undo/redo nuts and bolts which require a bit of effort. Really frustrating
I'm going to have to have someone local and, like us on here, I know what's needed and probably better how to do the job. C'est la vie!
Will report eventually as to how it goes. TBH with the gap tool to handle the air, it's really a straightforward job John
GAP iiD BT-Sold
Post #606050 9th Sep 2021 7:40pm
dingg1
Its getting those anti resonance dampers off the top of the strut that may be the issue imo Rolling Eyes
Post #606051 9th Sep 2021 7:46pm
Weegie
Had the job done today. As expected the damper was not straightforward. Very tight. My chap had SnapOn tools which were equal to the job.
I haven't done photos of the whole process but have attached some of what the damper consists of. With the correct tools it was a pretty straightforward job. I got new bolts for the bottom but couldn't source the dampers so the existing one went back on no problem.
Hope that is of help. I have done both on my Td6 which didn't have the dampers. I don't think, although I have a pretty comprehensive set of tools, that it would have been so easy.
 John
GAP iiD BT-Sold
Post #606487 15th Sep 2021 5:43pm
dingg1
Started mine yesterday, thought everything was going OK, until I couldn't get the bottom strut bolt out, absolutely solid, gave up this morning and put everything back together, found a land rover small garage, who is also the britpart agent on the silver coast, got there at 11.30 packed in for lunch at 2pm, first side completed at 4pm, same issue on the other side, bottom bolt was a right bastard again. Job completed at 6pm. He wouldn't give me a price for the job and I just hung about tge garage keeping an eye on them.
Cost me 10e each for the brothers lunch
And 80e for the work done ๐Ÿ˜‚๐Ÿ˜๐Ÿ˜๐Ÿ˜๐Ÿ˜Ž.
I will never ever scramble about under this car again
Post #606491 15th Sep 2021 6:45pm
Weegie
At that price it's not worth doing it yourself. I was well content at โ‚ฌ100 and he came to me and did it in the bsrn. John
GAP iiD BT-Sold
Post #606492 15th Sep 2021 7:34pm
Weegie
To amplify the photos for anyone contemplating doing the job with dampers:
The silver part is like a cup into which the black part screws. When unscrewing the black part the effect is that it loosens the retaining nut for the silver part and so the whole spins without unscrewing the black part.
The only way to separate both parts is to remove the strut and hold the silver part with some heavy duty grips whilst unscrewing the black part. There isn't, as far as I can see, any way to get to the silver part with grips in situ.
Hope that all makes sense
 John
GAP iiD BT-Sold
Post #606531 16th Sep 2021 9:36am
Danwilderspin
So my old struts had these big threaded caps with an Allen in the middle.
The new do not have and the old caps would not come offโ€ฆ
Any ideas? Iโ€™m using without currently
 Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #606798 19th Sep 2021 1:24pm
dingg1
They are a vibration damper, you will need to use an impact wrench with 14mm Allen drive and large grips to stop the housing from rotating, I bet some people don't bother refitting them tbh
Post #606803 19th Sep 2021 3:06pm
Weegie
As above, the black part unscrews but it requires heavy duty grips on the silver cup underneath to separate them. John
GAP iiD BT-Sold
Post #606810 19th Sep 2021 3:44pm
Danwilderspin
I had a high power air gun and my foot on some swan next it just kept spinning what grips did you use? How much are they new out of interest if under ยฃ20 Iโ€™ll replace them ๐Ÿ˜‚ Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #606826 19th Sep 2021 8:24pm
Weegie
I had the job done for me so didnโ€™t note the grips. Will try to find out John
GAP iiD BT-Sold
Post #606845 20th Sep 2021 6:38am
Danwilderspin
any truth to this (pinched from another forum)
I had exactly this issue a few weeks ago. I was reluctant to use an impact wrench as the black damper is plastic.
So, to be clear there are no threads on the damper - its glued in.
I used a hot air gun to warm everything up as much as I dare. Then used an allen key in the top of the damper and applied pressure smoothly rather than as an impact.
Once the glue lets go it will pull straight out.
Good luck ! Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #606916 20th Sep 2021 3:58pm
Weegie
Not plastic and, although LR state it has very strong thread lock, mine had just a smear. John
GAP iiD BT-Sold
Post #606921 20th Sep 2021 4:21pm
Page 2 of 3 <123>
