![]() | Home > Technical (L322) > Lower tailgate damper |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Well known problem, if you look closely you will see that your Fatty is upside down............. Pete
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
| Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454
Paaaahhaahahahaaaa |
I can’t even remember which way round mine is fastened on.
| Graham4242 Member Since: 26 Sep 2021 Location: Dubai Posts: 41
I’ve just had the same problem replacing a marginal one with a new one. The new one is a waste of space and I’ve tried fitting it both ways. |
The way up does not matter.
Ended up getting an LR part in the end. The batch of aftermarket parts are faulty. |
Did the genuine part work out? Current
| All times are GMT |
