Home > Technical (L322) > Lower tailgate damper
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
So I ordered a new lower damper (part no LR017455) and I fitted it today.
However it seems to be working in reverse, it doesn't slow the descent of the tailgate, it damps the ascent.
I'm guessing this is not normal behaviour.
The LR one I took off worked - just about - the other way around.
Reckon I have a dud part?
Post #607586 28th Sep 2021 1:57pm
Well known problem, if you look closely you will see that your Fatty is upside down............. Pete
Post #607587 28th Sep 2021 2:05pm
mjdronfield
Rolling with laughter
For off road use only….
Joking aside…. That’s not right….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #607588 28th Sep 2021 2:14pm
Caesium
Paaaahhaahahahaaaa Rolling with laughter
I've contacted the seller, awaiting a diagnosis. I'll upload a video in a bit
Post #607589 28th Sep 2021 2:21pm
mjdronfield
I can’t even remember which way round mine is fastened on.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #607593 28th Sep 2021 2:57pm
Graham4242
United Arab Emirates 2011 Range Rover Autobiography 5.0 SC V8 Alaska White
I’ve just had the same problem replacing a marginal one with a new one. The new one is a waste of space and I’ve tried fitting it both ways.
Post #607596 28th Sep 2021 3:06pm
Caesium
The way up does not matter.
Its the action of the damper itself that is the problem on mine.
When you close the tailgate it extends the damper rod and when you open it shortens it. My damper is stiff when extending but easy when contracting
Post #607597 28th Sep 2021 3:09pm
Caesium
Ended up getting an LR part in the end. The batch of aftermarket parts are faulty.
Post #608351 5th Oct 2021 4:30pm
Graham4242
Did the genuine part work out? Current
2011 Autobiography, 2014 Vogue SE Supercharged
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #608596 7th Oct 2021 10:49pm
