Home > Technical (L405) > Heater not heating |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Try & trace the heater pipes from the engine bay into the cabin. If they are getting hot in the cabin, then it would appear to be a distribution flap issue. |
2nd Oct 2021 11:30am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 443 |
Hi John, I think your first port of call after the above would be a code reader, then look under HVAC section for any faults, especially with blend motors ETC. It is a complex system when it goes pear shaped so best of luck and let us know how you get on. |
2nd Oct 2021 11:35am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1142 |
A plus one on the above post, to determine the true reason(s) for the failure, and go from there, even if the dash has to be stripped, £4-5000 sounds very high |
2nd Oct 2021 11:48am |
johnf Member Since: 16 Nov 2012 Location: Nottinghamshire Posts: 84 |
Thanks for the replies. Is the code reader I need an IIDTool BT? |
2nd Oct 2021 12:02pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
it may well be stuck flaps. try cycling through the manual buttons for face only, windscreen, feet etc.
2nd Oct 2021 12:10pm |
I've had a good read of the workshop manual. I've got the 4 zone climate control which uses a separate heater core and fan etc for the rear. So why would neither the front or rear heating work? I'm guessing I can rule out a faulty heater core or air distribution flaps? |
11th Oct 2021 9:47pm |
On further reading my current theory is a problem with the fuel burning heater changeover valve. It is designed to isolate the heating system from the engine coolant whilst the fuel burning heater is in operation. If it is stuck in the wrong position that would explain things. |
11th Oct 2021 10:09pm |
Just to report that my suspicion was correct. It was the changeover valve. Now changed for a new one and heating is restored. |
28th Nov 2021 2:47pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
Good spot John!
28th Nov 2021 4:13pm |
qwerty Member Since: 21 Oct 2015 Location: Bristol Posts: 54 |
An excellent result. Good detective work |
28th Nov 2021 4:20pm |
Tizzy Member Since: 07 Aug 2021 Location: Leicestershire Posts: 15 |
I’m wondering if that’s the problem with mine, as the symptoms sound extremely similar. Will get the valve changed! 2015 3.0 TDV6 Autobiography in Santorini Black with black-pack
29th Nov 2021 3:35pm |
One thing maybe worth mentioning was that the part (for my car LR117170) was out of stock at Landrover with no estimate of when it would be available. Found it on eBay in 10 minutes though. Fitted it myself which was straightforward but fiddly (very tight access for unclipping the hoses). Wonderful having a warm car again this morning. |
29th Nov 2021 11:25pm |
Well found John, glad to hear you sorted it for a reasonable price too |
30th Nov 2021 8:13am |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 205 |
Its also worth knowing that the valve is available as Bosch pt. no 1147412207 (its also used by Mercedes)
30th Nov 2021 9:30am |
