Home > Technical (L405) > Heater not heating
johnf
2013 Range Rover Autobiography 5.0 SC V8 Bonatti Grey
Heater not heating
Hi
I'm hoping someone can give me some advice please?
As the weather has turned colder I've realised that my heater isn't working. The aircon and fan both work normally but I'm just not getting any heat. I don't know whether this is because the heater core isn't getting warm or because the air distribution flaps aren't working properly. The engine temperature is fine so it doesn't look like a wider cooling system problem.
My local garage say I'll probably need a whole new climate control unit and, because this is a dash out job, I'm probably looking at £4-5K including labour. I'm keen to explore the possibility of a cheaper fix, and happy to do some investigations myself if someone could point me in the right direction?
Thanks
Post #607920 2nd Oct 2021 9:41am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Try & trace the heater pipes from the engine bay into the cabin. If they are getting hot in the cabin, then it would appear to be a distribution flap issue.
Post #607923 2nd Oct 2021 10:30am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Hi John, I think your first port of call after the above would be a code reader, then look under HVAC section for any faults, especially with blend motors ETC. It is a complex system when it goes pear shaped so best of luck and let us know how you get on.
Post #607924 2nd Oct 2021 10:35am
Merchy
A plus one on the above post, to determine the true reason(s) for the failure, and go from there, even if the dash has to be stripped, £4-5000 sounds very high Shocked
Post #607926 2nd Oct 2021 10:48am
johnf
Thanks for the replies. Is the code reader I need an IIDTool BT?
Post #607927 2nd Oct 2021 11:02am
Dolphinboy
it may well be stuck flaps. try cycling through the manual buttons for face only, windscreen, feet etc.
This should show if they are stuck or not.
Post #607928 2nd Oct 2021 11:10am
johnf
I've had a good read of the workshop manual. I've got the 4 zone climate control which uses a separate heater core and fan etc for the rear. So why would neither the front or rear heating work? I'm guessing I can rule out a faulty heater core or air distribution flaps?
Post #608888 11th Oct 2021 8:47pm
johnf
On further reading my current theory is a problem with the fuel burning heater changeover valve. It is designed to isolate the heating system from the engine coolant whilst the fuel burning heater is in operation. If it is stuck in the wrong position that would explain things.
Post #608891 11th Oct 2021 9:09pm
johnf
Just to report that my suspicion was correct. It was the changeover valve. Now changed for a new one and heating is restored.
Post #614014 28th Nov 2021 1:47pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Good spot John!
Those manuals are invaluable when we start self-diagnosing. I’d never had considered the FBH changeover valve! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #614019 28th Nov 2021 3:13pm
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
An excellent result. Good detective work Thumbs Up
Post #614020 28th Nov 2021 3:20pm
Tizzy
United Kingdom 2015 Range Rover Autobiography SDV6 Santorini Black
I’m wondering if that’s the problem with mine, as the symptoms sound extremely similar. Will get the valve changed! 2015 3.0 TDV6 Autobiography in Santorini Black with black-pack
2020 Evoque P300 HSE Dynamic
Past RR’s: 2018 SVR, 2016 Sport Autobiography SDV8 and an SDV6.
Post #614153 29th Nov 2021 2:35pm
johnf
One thing maybe worth mentioning was that the part (for my car LR117170) was out of stock at Landrover with no estimate of when it would be available. Found it on eBay in 10 minutes though. Fitted it myself which was straightforward but fiddly (very tight access for unclipping the hoses). Wonderful having a warm car again this morning.
Post #614208 29th Nov 2021 10:25pm
diesel Dave
Well found John, glad to hear you sorted it for a reasonable price too Thumbs Up
Post #614223 30th Nov 2021 7:13am
Fifth Horseman
Its also worth knowing that the valve is available as Bosch pt. no 1147412207 (its also used by Mercedes)
Many places show out of stock at the moment but UK-carparts seem to have stock at half the cost of the part from JLR
Post #614229 30th Nov 2021 8:30am
