![]() | Home > Maintenance & Mods (L322) > Seat not extending fully |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8800 ![]() ![]() ![]() |
Check nothing has got caught in the runners, change getting wedged in them is common..... also, if you put the seat all the way up it should help with getting to the front bolts... |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
Thanks for reply and advice, the problem is the runner does not fully clear the torx bolt so can’t get the socket on. Hoping there is some other way. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Further to the above advice, as the seat extends fully forwards, whilst in forwards position check that the rear runner bolts are tight and that the toothed sections on the runners appear to be in good order. If one or both are loose then the runners may not be parallel / dislodged and could cause the sticking.
All and any suggestions willingly received thank you.
Try an endoscope camera, if you or a mate has one, if not a USB one can be purchased for as little as £10 and connect it to your phone. Most have built in lights, I have used one on my fatty to help with fault finding, they are very handy and be easy to get under the seat. |
Great idea, many thanks |
Found the solution, on a Jaguar XF site !!
Nice work, thanks for posting the info. |
Hey, every cloud has a silver lining, I found £6 in coins and a pen I thought I lost searching with the endoscope. 😂😂 |
Perfect result |
