Home > Maintenance & Mods (L322) > Seat not extending fully
Sonearly
It appears my drivers seat does no longer fully extend. It goes fully forward but stops before fully extending backwards. Unfortunately it does not extend enough back to allow access to the front securing bolts so unable to see what the issue is.
Post #608197 4th Oct 2021 4:21pm
Check nothing has got caught in the runners, change getting wedged in them is common..... also, if you put the seat all the way up it should help with getting to the front bolts... Thumbs Up Pete
-Click here for Thread-
Post #608236 4th Oct 2021 8:13pm
Sonearly
Thanks for reply and advice, the problem is the runner does not fully clear the torx bolt so can’t get the socket on. Hoping there is some other way.
Post #608245 4th Oct 2021 8:45pm
Merchy
Further to the above advice, as the seat extends fully forwards, whilst in forwards position check that the rear runner bolts are tight and that the toothed sections on the runners appear to be in good order. If one or both are loose then the runners may not be parallel / dislodged and could cause the sticking.
Seat position micro switches ? not sure but must be something to tell the motor to stop at the end of the travel.
Maybe try moving the seat backwards whilst pushing the base with your hand?
Not a fix for right now, but hope this helps with fault diagnosis.
Post #608249 4th Oct 2021 9:13pm
Sonearly
All and any suggestions willingly received thank you.
I really think something is physically blocking runner, just can’t get to it
Post #608251 4th Oct 2021 9:23pm
Merchy
Try an endoscope camera, if you or a mate has one, if not a USB one can be purchased for as little as £10 and connect it to your phone. Most have built in lights, I have used one on my fatty to help with fault finding, they are very handy and be easy to get under the seat.
Post #608254 4th Oct 2021 9:39pm
Sonearly
Great idea, many thanks
Post #608261 4th Oct 2021 11:22pm
Sonearly
Post #608262 4th Oct 2021 11:23pm
Sonearly
Found the solution, on a Jaguar XF site !!
When you re configure some ECU’s modules you have to reset the clock, windows etc. Apparently it can also instigated a “stall process” in some of the preset settings for the seats. In this case within the seat module. The simple solution is similar to resetting the windows. Full extent of the movement, release the switch and then hold again for 5 seconds, the preset is then over ridden and allows full movement of the seat.
Useful info to know.
Post #608392 5th Oct 2021 9:09pm
Merchy
Nice work, thanks for posting the info. Thumbs Up
Life with a fatty seems to be a never ending learning curve, or sometimes described as Banging Head
Post #608409 5th Oct 2021 10:04pm
Sonearly
Hey, every cloud has a silver lining, I found £6 in coins and a pen I thought I lost searching with the endoscope. 😂😂
Post #608412 5th Oct 2021 10:46pm
Merchy
Perfect result Thumbs Up Check under the passenger seat as well, you could end up a wealthy man Rolling with laughter
Post #608415 5th Oct 2021 11:26pm
