Home > Maintenance & Mods (L322) > Battery conditioning how do you do it?
Page 3 of 3 <123
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
At last! I'm so pleased I joined this forum. Been trying to find this info for ages!
I thought that I might have to connect to the jumping terminals under the bonnet. That's a problem for me as I have to go forward into my garage then cannot open the bonnet.
I've got a CTEK 5.0, just need to get the cigarette lighter thing so I can go through the tailgate.
Cheers!
Post #608690 9th Oct 2021 9:13am
DrRob
Got towing electrics? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #608698 9th Oct 2021 9:51am
RRV8SC
Not that I am aware of. There is a blanking piece on the rear bumper, I guess that's where it might be?
Post #608705 9th Oct 2021 10:32am
RRV8SC
fanders wrote:
CTEK MXS 7.0 plugged into the boot 12V aux sockets which is permanently live. Works well, the CTEK charging lead is small enough to go past the seal between the upper and lower tailrgate. This setup is in a garage.
fanders
I've tried that with my CTEK 5.0 and just taken delivery of the cigarette lighter plug.
It doesn't seem to work. I've tried it in the boot, the rear passenger sockets and the driver's socket.
Tried it with ignition off, ignition on and nothing.
If I start the car then it works! So it appears that my sockets are not live if the engine is not actually running.
Am I doing something wrong?
Post #608809 10th Oct 2021 7:28pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I’ve got a NOCO genius as my CTEK MSX5.0 was taking forever to charge up a car and it doesn’t support Li-ion batteries.
Going to knock up a fly lead to the tow port too.
Post #608810 10th Oct 2021 7:34pm
RRV8SC
Wouldn't it be a great option if there was a properly engineered and installed socket where you could easily plug in your CTEK charger? After all, the CTEK charger is sold as a genuine Land Rover branded accessory. Be nice to be able to connect it without all this fuss.
Post #608812 10th Oct 2021 7:41pm
Caesium
Land Rover would never do that as it suggests that the car has a current drain issue, necessitating the need for a charge port.
Even though I think it's a good idea you can imagine what the motoring press would make of it.
Post #608837 11th Oct 2021 10:59am
G6 ROO
I'm in the process of investigating a non working FBH on my 2012 TDV8 and want to rule out low battery voltage as a possible cause. Fuel Primer and FBH diagnostic tests using GAP IID appear to be successful but only with the engine running (once I clear the E7 by pulling the fuse). GAP is reading just 12v with ignition on which I think maybe marginal for the FBH ?
So, I next want to try having the battery on charge when I test it with engine off so that there is more than 12v in it when I test, but the owners manual specifically states not to charge the battery on the vehicle or else damage can occur. Finding this thread has made me think that it is actually ok to charge on the car either by direct connection th the battery terminals or through the towing socket or 12v aux boot socket which I will probably do as a more permanent solution once I have aquired a C-Tek or Optimate conditioner.
Am I right to think that I won't do any harm by charging on the car ?
Thanks
Post #608883 11th Oct 2021 9:07pm
Page 3 of 3 <123
