Home > Maintenance & Mods (L322) > Battery conditioning how do you do it? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4226 |
Got towing electrics? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
9th Oct 2021 9:51am |
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 147 |
Not that I am aware of. There is a blanking piece on the rear bumper, I guess that's where it might be? |
9th Oct 2021 10:32am |
I've tried that with my CTEK 5.0 and just taken delivery of the cigarette lighter plug. It doesn't seem to work. I've tried it in the boot, the rear passenger sockets and the driver's socket. Tried it with ignition off, ignition on and nothing. If I start the car then it works! So it appears that my sockets are not live if the engine is not actually running. Am I doing something wrong? |
10th Oct 2021 7:28pm |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
I’ve got a NOCO genius as my CTEK MSX5.0 was taking forever to charge up a car and it doesn’t support Li-ion batteries.
10th Oct 2021 7:34pm |
Wouldn't it be a great option if there was a properly engineered and installed socket where you could easily plug in your CTEK charger? After all, the CTEK charger is sold as a genuine Land Rover branded accessory. Be nice to be able to connect it without all this fuss. |
10th Oct 2021 7:41pm |
Land Rover would never do that as it suggests that the car has a current drain issue, necessitating the need for a charge port.
11th Oct 2021 10:59am |
G6 ROO Member Since: 02 Aug 2021 Location: Skipton, North Yorkshire Posts: 6 |
I'm in the process of investigating a non working FBH on my 2012 TDV8 and want to rule out low battery voltage as a possible cause. Fuel Primer and FBH diagnostic tests using GAP IID appear to be successful but only with the engine running (once I clear the E7 by pulling the fuse). GAP is reading just 12v with ignition on which I think maybe marginal for the FBH ?
11th Oct 2021 9:07pm |
