![]() | Home > Technical (L322) > Parking Sensor |
Growl Member Since: 22 Sep 2021 Location: Staffordshire Posts: 21 ![]() ![]() ![]() |
Sorry 'been' should read 'beeb' bloody auto correct |
This is my module |
This, sorry |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
I had issue with sensors when I got my FF. It turned out the sensors were all fine but the wiring that runs to them had been trapped and was damaged. Probably when the bumper had been removed previously. If you pull the bumper off and check the wiring I would hazard a bet that you will find a break. L322 2007 TDV8 3.6 |
Brilliant, thank you |
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 ![]() ![]() ![]() |
I had the same on mine. The bumper had been off for paint when I bought it. The sensor loom dropped down and was melted by the exhaust...... on the test drive!
If it's any help I've had a listen with a stethoscope and none of the sensors are clicking |
Sounds like a loom fault. L322 2007 TDV8 3.6 |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Pretty sure on your car the sensors don't click. Bish.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
A plus on above post, read somewhere that only the earlier sensors make a discernible noise.
Hi, cheers, I have tried it with both the switch and by putting it in reverse, long beep, light flashes on switch a couple of times but no joy from the sensors |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35790 ![]() ![]() |
https://www.fullfatrr.com/forum/topic61071.html ... - .- -.
Cheers, but I've tried 2 new modules in it but no improvement |
