Home > Technical (L322) > Parking assist system stopped working
JayGee
Backed it into a tree Embarassed (gently) it was working a week ago…
Light on switch won’t illuminate when pressed but no warning beeps.
Iid tool fault U0159-00 lost communication with parking assist control module.
Most of the errors / faults seem to be with a faulty sensor which throws beeps etc but not a totally dead system
Where to start after checking the fuse? 2012 TDV8 Vogue (L322)
Post #607959 2nd Oct 2021 5:32pm
i had this with my old westie ..turned out to be a faulty parking aid module in the rear near side cubby.. ... - .- -.
Post #607979 2nd Oct 2021 7:35pm
bishbosh10
Exactly the same symptoms as I had. After spending hours dismantling both front and rear bumpers to check the sensors, which were all fine, I bought a used module for £99 and fitted it in about 2 minutes flat. No more problems. Smile Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #608046 3rd Oct 2021 1:53pm
JayGee
Fuse is good so ECU it is then - presume they are all the same? 2012 TDV8 Vogue (L322)
Post #608064 3rd Oct 2021 4:12pm
JayGee
2012 it's not behind the fuse box on the right but low down in the left load space compartment
Puller the plugs and there was some greenish corrosion on the pins but a brush up and squirt of WD-40 hasn't fixed it. Looks like a completely different unit to the earlier ones as well. 2012 TDV8 Vogue (L322)
Post #608076 3rd Oct 2021 4:44pm
thats what i said, rear near side... ... - .- -.
Post #608088 3rd Oct 2021 5:13pm
JayGee
Thanks - should have read carefully before looking at youtube videos...... 2012 TDV8 Vogue (L322)
Post #608089 3rd Oct 2021 5:16pm
JayGee
Can't work out what is the right part for this. Seems it's a common component on JLR and Fords. I suspect the key code is '15k866' but can't be 100% sure and there are no items I can find with the exact codes I have. 2012 TDV8 Vogue (L322)
Post #608562 7th Oct 2021 3:20pm
JayGee
Swopped out the ECU but system still dead - any fault tracing diagnostic procedure out there or even a circuit diagram? 2012 TDV8 Vogue (L322)
Post #609021 13th Oct 2021 1:16pm
bishbosh10
WSM is in the Wiki.
Wiring is easy (ish) to follow - I'm no electrician and managed it.
The bumper covers will need to come off to get to the looms though which are a bit of a pain to remove.
My approach here:
https://www.fullfatrr.com/forum/topic58516.html
Good luck! Bish.
2005 110 TD5 CSW
Post #609281 15th Oct 2021 2:21pm
JayGee
Thanks. I'm pretty sure it's the ECU as when I pulled it apart there was some green Verdigris on the bottom of the board so some water must have got in there at some point. Also I'm assuming as the switch light doesn't even illuminate that it's not a sensor or sensor wiring problem. Really need to get this fixed so may have to pony up £200 for a new ECU as there are none with that part number on Ebay. 2012 TDV8 Vogue (L322)
Post #609294 15th Oct 2021 3:46pm
RJPotts
https://www.gentlemenofsalvage.co.uk/produ...7923065916 (listed as out of stock but call for availability), suppose a call might yield results
Or submit a request on https://www.breakerlink.com/ ? 2010 Range Rover Autobiography TDV8 Santorini Black
2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone]
2003 Range Rover HSE Oslo Blue [Gone]
1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone]
1990 Camel Trophy 127 (Workshop Vehicle) [Gone]
1989 Camel Trophy 110 (Workshop Vehicle) [Gone]
1998 Camel Trophy Freelander (South African Team Vehicle)
1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone]
Post #609299 15th Oct 2021 4:35pm
JayGee
Many thanks - will make an enquiry. 2012 TDV8 Vogue (L322)
Post #609300 15th Oct 2021 4:45pm
bishbosh10
You'll get a forum discount from Duckworths - drop them a message. Thumbs Up Bish.
2005 110 TD5 CSW
Post #609590 18th Oct 2021 12:20pm
JayGee
2 used a brand new module later and the switch now at least flashes. Too dark to do any more investigating but next job is sensors and wiring..... 2012 TDV8 Vogue (L322)
Post #613423 22nd Nov 2021 4:07pm
