Home > Technical (L322) > PAS fluid colour
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
PAS fluid colour
Can anyone advise the colour of new PAS fluid?
This is the colour of my current fluid. Trying to judge it's age.
Post #608850 11th Oct 2021 1:59pm
DrRob
Green when mine was renewed Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #608851 11th Oct 2021 2:12pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Yes, it should be green. I used this
Jim
Post #608866 11th Oct 2021 4:55pm
Caesium
I've concluded this oil is definitely past it's best.
Ordered 5 litres from Smith & Allan.
The manual states 4 litres need to be used to flush properly so I'll put that on the list of things to do next.
Post #608868 11th Oct 2021 5:04pm
knwatkins
Good choice. I also use the Smith and Allan Cold Climate fluid. I used to use it on my old L320 RRS in the power steering system and the dynamic response system. I now use it in the L405 dynamic response also. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #608875 11th Oct 2021 6:41pm
DrRob
I used the Febi cold climate from Advanced Factors. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #608885 11th Oct 2021 8:19pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
If in doubt, get it out mate.
Best advice I can give, pretty simple job changing pas fluid. Just like anything, it can be time consuming
Post #608898 11th Oct 2021 10:07pm
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
I thought all PAS fluid was red, obviously not. What’s the difference? Can they be mixed? 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #608903 11th Oct 2021 11:35pm
Caesium
PAS fluid is normally just ATF which is generally red.
The RR takes cold climate fluid which is less viscous, it appears to be green from LR. Not sure what colour the stuff I'll get will be as its not coming from LR, but is a compatible alternative. Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #608938 12th Oct 2021 2:58pm
Baltic Blue
I hope someone does a write up of how to change it.
Mine is 10 years, 80,000 mls old, so probably overdue.
I have got a Draper oil suction pump , but not sure if that is the way to go about it ??.
Any help appreciated.
Mike.
PS,
I never changed it in my Td6, 100,000+ miles and twelve years old when I p/x it.
Post #608940 12th Oct 2021 3:34pm
Classic888
Try page 526 of the WSM, it gives details of the fluid flushing/refill. I did mine like this. Caution is needed as it does pump the fluid in FAST. Diagram shows a RRS !!!
Post #608943 12th Oct 2021 3:51pm
there is also a youtube video but again its for the sport...cant be far off being the same as a L322??? ... - .- -.
Post #608944 12th Oct 2021 3:56pm
Caesium
Mike.
PS,
Mike.
The car pumps it out if you start it up. It's a matter of removing the return hose from the reservoir and directing into a bucket while you top up the oil until it runs out clear.
The workshop manual details the process quite clearly. You just need to ensure you have a helper and a big funnel to get the oil back in as quick as it pumps it out. Christian.
Current Cars
2019 BMW X4
or
Post #608950 12th Oct 2021 5:05pm
DrRob
Yep. All in workshop manual. I had Glenrands to do it for me Wink Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #608953 12th Oct 2021 5:24pm
knwatkins
It'll be this colour...
 Kev
Post #608961 12th Oct 2021 6:58pm
