![]() | Home > Technical (L322) > PAS fluid colour |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Green when mine was renewed Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| jim4244 Member Since: 31 May 2012 Location: UK Posts: 855
Yes, it should be green. I used this
| Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454
I've concluded this oil is definitely past it's best.
| knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782
Good choice. I also use the Smith and Allan Cold Climate fluid. I used to use it on my old L320 RRS in the power steering system and the dynamic response system. I now use it in the L405 dynamic response also. Kev
I used the Febi cold climate from Advanced Factors. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929
If in doubt, get it out mate.
| Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186
I thought all PAS fluid was red, obviously not. What’s the difference? Can they be mixed? 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
PAS fluid is normally just ATF which is generally red.
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888
I hope someone does a write up of how to change it.
| Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233
Try page 526 of the WSM, it gives details of the fluid flushing/refill. I did mine like this. Caution is needed as it does pump the fluid in FAST. Diagram shows a RRS !!! |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
there is also a youtube video but again its for the sport...cant be far off being the same as a L322??? ... - .- -.
The car pumps it out if you start it up. It's a matter of removing the return hose from the reservoir and directing into a bucket while you top up the oil until it runs out clear. The workshop manual details the process quite clearly. You just need to ensure you have a helper and a big funnel to get the oil back in as quick as it pumps it out. Christian. Current Cars 2011 Range Rover Vogue SE 2020 BMW M4 Competition 2019 BMW X4 My RR Blog: www.facebook.com/L322Project or https://www.fullfatrr.com/forum/topic61540.html |
Yep. All in workshop manual. I had Glenrands to do it for me |
It'll be this colour...
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
| All times are GMT |
