Home > Technical (L322) > fuel presure problem
pablo
Ireland 2012 Range Rover Westminster TDV8 Fuji White
hi guys first time posting so need your help badly.i had a problem with the car going into limp mode with RP found the problem it was the MAP sensor,now its saying FUEL PRESSURE INTERMITTENT. id be driving along no problem and as soon as it goes into 7th or 8th gear and i put my foot down to overtake bang.....red warning triangle RP. has any body else hadthis problem because its driving me mad.the car is a 4.4 tdv8 westminister 2012 and ive just given it a full service with OEM parts.
cheers Paul
Post #609059 13th Oct 2021 7:56pm
kevinp
Was it doing it before you serviced it?
Post #609075 13th Oct 2021 10:31pm
pablo
yes it was,when i got the dpf cleaned the guy said there was a fuel pressure problem that kept coming up on the computer but would not show any codes
Post #609077 13th Oct 2021 11:24pm
pablo
when the car is running right i swear to god its like a ferrari the power is unreal but this fault is getting on my nerves.
Post #609079 13th Oct 2021 11:41pm
Discotigger
Have a look at the four short rubber hoses that are connected into the intake plenum (large plastic doughnut shaped box, located under the engine cover) and see if there's any soot/oil/or splits/cracks, etc. They are a common weak spot on the 4.4 TDV8 engine and will set off the Restricted Performance problems, often at random but more usually under hard acceleration.
Do a search on this forum, there's plenty of info on this.
It's a good place to start Thumbs Up
Post #609083 14th Oct 2021 12:19am
pablo
yes there is a black sootat the back right hand side rubber a bit like a diesel leak could that be it?
Post #609178 14th Oct 2021 6:22pm
Discotigger
Check the hose to see if there's a split.
Have you still got the original hoses or have they been replaced with either the newer LR upgraded hoses or the silicone equivalents.
Maybe take a few pics and post them up, that may help with the diagnosis, but it sounds like it could be a culprit. It's relatively easy to replace the hoses. There's a good thread on here on the issue, but I couldn't remember the title of the thread offhand.
Post #609212 14th Oct 2021 9:30pm
pablo
ill post photos tomorrow,thanks very much for your help.
Post #609216 14th Oct 2021 9:56pm
Site Copyright © 2006-2021 Futuranet Ltd & Martin Lewis
