Home > Maintenance & Mods (L405) > L405 Turbo Issue
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
L405 Turbo Issue
I noticed an oil drip on my drive when I removed the under trays they were covered in oil . Also noticed oil near near side turbo drivers side was dry. Took car to independent RR garage with great reputation. Was informed I need two new turbos although car was running fine. I have been quoted approx 7k for work . I was also advised I could drive car as long as I didn’t thrash it while I’m waiting for it to go in (2 months) would be grateful for any comments or advice
Post #609293 15th Oct 2021 4:45pm
knwatkins
I'd give it a good clean up with brake cleaner, drive it for a week or so then inspect it again to see where the oil is coming from. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #609303 15th Oct 2021 6:52pm
cass
When I bought my L322 4.4 TDV8 the paperwork from the last MD service came with it. There was an "advisory" that the N/S turbo needed changing as it was leaking oil. 5 years and over 80K miles later it is still leaking oil. I've never needed to top the oil up and it has never got any worse.
£7k would make me see if I could live with the problem or see if it gets any worse.
Post #609360 16th Oct 2021 11:15am
Pat
Thanks for that
If warranty company pays for it I will go ahead other wise I will do what you have done
Post #609389 16th Oct 2021 4:06pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I believe that on the L405, changing turbos require the engine to come out. This is probably why it is so expensive. You might find an independent who would do the job for less than £7k as most of the cost will be in labour hours. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #609391 16th Oct 2021 4:31pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
As long as the leak isnt internal and making it's way to the outside, IF this is the case it's a ticking bomb for the engine running away when it uses it's own oil as fuel. Be sure where the leak is if youre going to keep running it. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #609405 16th Oct 2021 7:17pm
Pat
Hi Thanks for the reply. Could you elaborate on this "ticking time bomb" If the leak was internal what is the likely outcome if I continue to run car
TIA
Post #613913 26th Nov 2021 10:49pm
AJGalaxy2012
IF the seals are leaking internally, this is what can (and does) happen.
https://youtu.be/fJIcxMJevII BMW i3 Electric Car
Post #613929 27th Nov 2021 6:36am
