Home > Maintenance & Mods (L405) > Brand New Autobiography windscreen fogging up whilst parked
Hoyboy
Had this car a month now. I’ve noticed recently that when the car is parked up the windscreen fogs up. The car was last driven yesterday and this is what it looks like now.
(Also I don’t know what’s up with the circle marks on each side of the windscreen, they’ve been there since we’ve had the car).
Is this normal for this model or do you think there’s a problem with it? No sign of any leaks anywhere, I mean there shouldn’t be on a brand new car. It’s already booked in a the end of the month for some minor things that need fixing but just wanted to know if this is normal in case the dealer tries to fob me off.
Thanks.
Post #610024 21st Oct 2021 8:21pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
There's water somewhere in the car.
The circle marks are from the suckers used to install the screen. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #610033 21st Oct 2021 9:33pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Check the carpets aren’t wet. As mentioned there’s a significant amount of water getting into the cabin Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #610036 21st Oct 2021 10:12pm
Hoyboy
Yeah I’ve looked everywhere I can think of in the car but can’t find any water / anything wet. The carpets are bone dry as well. Bit puzzled by what’s causing it.
Post #610037 21st Oct 2021 10:20pm
Caesium
Check the coolant level (heater matrix could be leaking) and the air intakes under the bonnet - can get full of leaves and crud on other cars, not sure if RR’s suffer but worth a look as the leaves can cause rain to flow in behind dash Christian.
Current Cars
2019 BMW X4
or
Post #610039 21st Oct 2021 10:30pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
If it had been stood outside for a bit it could just have a lot of condensation inside - mine has steamed up when parked somewhere sheltered for a while. I’d see what happens after a long drive to clear it out.
Post #610040 21st Oct 2021 10:32pm
Hoyboy
Ok thanks will do. Will check in the morning when I can see properly
Post #610042 21st Oct 2021 10:39pm
Hoyboy
Yeah it lives outside on the driveway. It was driven yesterday and it steamed up a lot when driving it but I put it down to it raining and people sitting in the car etc. but it had cleared up by the time I got home. After a day of it sitting there it’s just steamed up by itself again with no one in it.
Post #610044 21st Oct 2021 10:42pm
cass
Is the AC working?
Post #610050 22nd Oct 2021 3:29am
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Just to build on Cass comment - are you running the AC? If not make sure you are for the next few trips as the AC will take moisture out of the air and start to dry out the car.
Even in winter I find I have to run the AC for a while when it is cold as it helps with the demist.
Maybe you already are running AC in which case ignore the above - and see if you can take it for a few long runs where you have the cabin nice and toasty to dry it out. Likely just build up of moisture as said above if it has been standing for a while.
Could also check door seals and anywhere where moisture might enter.
Cheers,
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #610056 22nd Oct 2021 9:20am
Hoyboy
Just had a look and there’s nothing leaking or any leaves etc
Post #610085 22nd Oct 2021 1:34pm
Hoyboy
Cheers,
MM
Tbh no we haven’t really used the AC. Only times it’s on is when we press the max defrost button to clear the windscreen while driving. The AC definitely works though it’s just not on for long when we use it. I’ll try warm it all up and see if that helps solve it. Thumbs Up
Had a look at the door seals etc and everything seems like normal.
Cheers
Post #610087 22nd Oct 2021 1:42pm
Hoyboy
cass wrote:
Is the AC working?
Yeah AC is working fine for the brief time we’ve used it.
Post #610088 22nd Oct 2021 1:44pm
cass
That’s probably your your problem, the AC dries the air.
There isn’t any reason to turn it off in a modern car and lots of reasons to keep it running permanently.
Post #610089 22nd Oct 2021 1:57pm
Hoyboy
Oh wow didn’t know that about running it permanently, learn something new everyday!
Only problem is the missus hates using the air con so will have try give it a go next time I’m in it by myself.
Post #610091 22nd Oct 2021 2:06pm
