![]() | Home > Maintenance & Mods (L322) > NO power (not limp mode) idle at 500rpm - now non starter . |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
So, is the oil level OK, and does it start with the top turbo hoses disconnected from the engine? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8718 ![]() ![]() ![]() |
I presumed the guys who looked at it would have done all those basic checks... maybe it will be an easy fix after all... looking forward to seeing what it is...
Kevhdkent Member Since: 27 Oct 2021 Location: Kent Posts: 69 ![]() ![]() |
I certain will, Pete.
Hi Mikey, no chance to attempt a start with hoses disconnected, possibly tomorrow. I assume if this somehow allows the motor to run it’ll sound like something out of Mad Max ?! |
There will be a bit of an induction roar but not that loud, the exhaust will remain as it is...
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 775 ![]() ![]() |
@Kevhdkent, I don't know if you've seen many of Mikey's posts on here and other LR forums buy he fixes these for a living.
Thanks for the advice Cass.
We are trying to confirm/eliminate turbos as the failure
Hi Mikey,
(ps when the hoses are off the throttle bodies still non starter) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2727 ![]() ![]() |
The butterflies are only used to increase exhaust gas recirculation by blocking fresh air when the ecm detects that more exhaust gasses should be ingested and are fully open at all other times. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
The fact you have induction and it doest fire with easystart points to total loss of compression IMHO. Have you done a compression test? does your hand get pushed off the exhausts when cranking i.e. are there gases being pumped out? BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
You now need to loosen off the EGR pipes at the back of the engine and try again |
I will check pressure at exhaust tomorrow. If it is a critical loss of pressure across every cylinder could this reasonably be accounted for by anything other than cam belt/chain (which is it ?) failure ? |
