Home > Maintenance & Mods (L322) > Sticking rear caliper
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
So I thought I would check my rear brakes just on the off chance as I saw someone mention that could be a cause of the droning/vibration at speed.
This is the nearside after a short run:
This is the offside:
Got the wheel off as soon as I could and it looks like the piston is really stiff in the bore.
Question now is do I rebuild them or just replace. If the latter does anyone know where I can get new pistons? Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #611702 5th Nov 2021 3:41pm
Snowy90 L322
United Kingdom 2019 Range Rover Vogue SDV6 Baltic Blue
Just my opinion but i would first push the piston out by pressing the brake not so much it pops out and inspect it. if its badly pitted i would say the caliper lining is as well and probably needs replacing.
If it looks fine I would grease the piston and repeat procedure a few times to see if it frees up.
Also carefully check the sliding caliper pins for pitting and corrosion again if ok copper grease and reassemble.
Try a run and see if the temp drops
Post #611703 5th Nov 2021 4:02pm
Caesium
I'm not sure I'm comfortable with putting copper grease on the piston. Not sure where you got that suggestion from, I've never heard of that before.
I have ordered a new set of pistons and seals from Rimmer Bros just now. I'll overhaul them as they are genuine TRW LR callipers.
I lifted the dust boot and could not see any corrosion or scoring on the piston at all. Christian.
Current Cars
2019 BMW X4
or
Post #611704 5th Nov 2021 4:06pm
Baltic Blue
Was the difference between the temperatures obvious to a touch by hand on the wheel ?
I am just curious because I haven’t got the luxury of an infrared temperature gauge and should check mine because they haven’t been serviced for a few years other than checking plenty of pad wear left.
Post #611708 5th Nov 2021 4:25pm
Caesium
Yes, the nearside was almost stone cold (ambient temperature) and the offside was boiling hot. The wheel was warm.
It's got so hot there the pad wear sensor is partially melted. Christian.
Current Cars
2019 BMW X4
or
Post #611709 5th Nov 2021 4:35pm
Baltic Blue
Thanks for reply.
I have just done the touch test on mine after a five mile errand run and both sides only just above cold.
Post #611710 5th Nov 2021 4:40pm
Caesium
I reckon you're good to go then.
I fitted my retraction tool to stop the piston coming right out and I pushed the piston out with the pedal and it took a lot more effort than it should do. I'll take some pictures when I refurbish the callipers. Christian.
Current Cars
2019 BMW X4
or
Post #611711 5th Nov 2021 4:54pm
Snowy90 L322
Yes you are right the copper grease can affect rubber components, that said most garages seem to use it on anything! Rubber Grease or Brake assembly or most other hiigh temp grease is what's used
Post #612062 8th Nov 2021 6:06pm
