![]() | Home > Maintenance & Mods (L322) > Sticking rear caliper |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
So I thought I would check my rear brakes just on the off chance as I saw someone mention that could be a cause of the droning/vibration at speed.
I'm not sure I'm comfortable with putting copper grease on the piston. Not sure where you got that suggestion from, I've never heard of that before.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3854 ![]() ![]() ![]() |
Was the difference between the temperatures obvious to a touch by hand on the wheel ?
Yes, the nearside was almost stone cold (ambient temperature) and the offside was boiling hot. The wheel was warm.
Thanks for reply.
I reckon you're good to go then.
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
Yes you are right the copper grease can affect rubber components, that said most garages seem to use it on anything! Rubber Grease or Brake assembly or most other hiigh temp grease is what's used |
