Home > Maintenance & Mods (L322) > Change mileage interval for service indicator?
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
I've long been in the habit of doing my car servicing every 5K miles regardless of what the car says. If the manufacture has special procedures (belts, plugs, etc.) above and beyond I do those at the recommend mileage/time.
Right now I have about 52.5K miles and it's telling me it's time for an oil service but I did it at 50K and my next isn't due (by my service schedule) until 55K miles.
Is there a way I can reset the oil service indicator now and then when I do my oil service at 55K reset it again so my next oil service comes on at about the right time? I have the IID tool if that helps.
Thanks!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #611847 6th Nov 2021 8:10pm
Baltic Blue
You can reset the service warning easily enough at any time with your iid, but I don’t think you can alter the frequency .
Just reset it to Zero after each oil service and note the mileage.
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #611855 6th Nov 2021 9:42pm
lschwarcz
Thanks for the info!
Bournville/Ivory
Post #611865 6th Nov 2021 11:24pm
p38arover
Australia
What about for BMW based systems. i.e., 2002-2004/5?
Yes, I can reset it using this method:
Quote:
Resetting the Oil Service or Service Interval Message.
Ignition key must be “off”.
• Press and hold the trip odometer button in the instrument cluster (left button), and turn the ignition key to the first position (KLR).
• Keep the button pressed for approximately 5 seconds until one of the following words appear in the display: “OIL SERVICE, or “INSPECTION”, with “reset”.
• Release the reset button and press and hold it again until “reset” begins to flash.
• While the display is flashing, press the left button briefly to reset the service interval.
After the display has shown the new interval, the following will appear: “END SIA”
But I think 25,000km is too long and want to change the value to 10,000km (max).
FYI, I have a GAP IID, T4 (Testbook), and Faultmate MSV. I also have access to a local indie's Autologic. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #652720 6th Jan 2023 2:47am
Phoenix
I think you can change it to the 'arduous use' schedule with Autologic, there isn't the option to set your own values but you can turn it off altogether. I'll have a look tomorrow and get some screenshots.
Post #652724 6th Jan 2023 8:14am
p38arover
Australia
Thanks Phoenix. I'm going to my indie's workshop on Tuesday so that info would be useful. I can grab his Autologic.
I don't mind leaving it on but I would like a shorter interval. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #652725 6th Jan 2023 8:18am
Phoenix
It seems the service interval can only be changed on 06 onwards, at least with Autologic
02 - 06
06 On
just reject them
It may well be worth trying the 06-09 MY, if the IPK doesn't recognise the commands, it'll just reject them. I can't remember anything on T4, not even with my 'access all areas' login, that allowed access to change the SIA.
Hope that helps!
Post #652910 7th Jan 2023 9:55pm
Larry, with the bonnet or hood open, the driver's door open, switch the ignition on without starting the car... Put both feet HARD down on the brake and the throttle peddles and wait! 10 seconds or so and you should get a message on the dash saying "resetting service milage" hold down and wait and then it will tell you its "reset service milage" and voila! oil reset completed sir... Thumbs Up
Post #652927 8th Jan 2023 12:28am
p38arover
Australia
^^ Thanks Phoenix. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #652932 8th Jan 2023 4:26am
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
Thanks, Craig
Neat trick ! Thumbs Up "it needs some intelligence to undestand you may not have enough"
Post #652961 8th Jan 2023 12:54pm
No problem sir… It’s a weird phenomenon that’s worked on Range Rovers for many years… 👍
Post #652963 8th Jan 2023 1:04pm
