![]() | Home > Maintenance & Mods (L322) > Change mileage interval for service indicator? |
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 276 ![]() ![]() ![]() |
I've long been in the habit of doing my car servicing every 5K miles regardless of what the car says. If the manufacture has special procedures (belts, plugs, etc.) above and beyond I do those at the recommend mileage/time.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
You can reset the service warning easily enough at any time with your iid, but I don’t think you can alter the frequency .
Thanks for the info!
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
What about for BMW based systems. i.e., 2002-2004/5?
But I think 25,000km is too long and want to change the value to 10,000km (max). FYI, I have a GAP IID, T4 (Testbook), and Faultmate MSV. I also have access to a local indie's Autologic. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
Thanks Phoenix. I'm going to my indie's workshop on Tuesday so that info would be useful. I can grab his Autologic.
It seems the service interval can only be changed on 06 onwards, at least with Autologic
Larry, with the bonnet or hood open, the driver's door open, switch the ignition on without starting the car... Put both feet HARD down on the brake and the throttle peddles and wait! 10 seconds or so and you should get a message on the dash saying "resetting service milage" hold down and wait and then it will tell you its "reset service milage" and voila! oil reset completed sir... |
^^ Thanks Phoenix. Ron B. VK2OTC
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 124 ![]() ![]() ![]() |
Thanks, Craig
No problem sir… It’s a weird phenomenon that’s worked on Range Rovers for many years… 👍 |
