![]() | Home > Maintenance & Mods (L322) > NO power (not limp mode) idle at 500rpm - now non starter . |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1829 ![]() ![]() |
Downpipes off the back of the turbo |
Kevhdkent Member Since: 27 Oct 2021 Location: Kent Posts: 69 ![]() ![]() |
Thanks. I take this will be accessed from under the car having removed the sump guards ? |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2684 ![]() ![]() |
Both sides blocked simultaneously? Do the 2 pipes going into the rear muffler join inside the muffler? |
Don't need the guards off. But they are awkward to access. They will be tight |
Both sides won't block simultaneously, usually the LH seizes. It doesn't turn, which then chokes the 4 LH cylinders, and pressurises the crankcase. This then finds its way out the crankcase breather and is drawn into the RH turbo/intake ![]() |
Thanks Mikey. |
LH, as viewed from the drivers seat |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1352 ![]() ![]() |
Well done guys, I'm off to bed |
Just out to investigate down pipes & turbos. Now here’s the crunch point. If turbo(s) need replacing is this BODY OFF/ENGINE REMOVAL as I’ve been lead to believe ??? |
Strictly speaking, no.
Thanks Mikey.
You can raise the car with suitable diagnostics without the engine running
Bear that in mind.
Probably the last post for a little while.
