![]() | Home > Maintenance & Mods (L322) > Sidelight upgrades |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Anyone ever investigated an upgrade to the sidelights?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
yes these fairy lights are pants...i tried upgrading them but my upgrade wasnt very successful,
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
Stan,
few ways of doing this Mike....simplest way is to replace the halogen bulb with a led bulb and cut the fog wiring and connect to a drl switch..
Thanks Stan,
re the carplay, i just bought an used one of ebay so it will be interesting to see what these things can do.. ... - .- -.
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Soooo...... back to sidelight bulb replacements..... |
Apologies for causing a drift off topic.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
If you upgrade to DRL you should really wire them through a normally closed relay so that when the headlamps are on the DRL lights knock off.
Thanks V8 Bob, but I don't want to upgrade to DRLs. I just want to try to seek recommendations for replacing the poor, yellow
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3329 ![]() ![]() ![]() |
Gyre8,
Ah. Thanks dhallworth. Do your LEDs give canbus errors? And can you give any info (product, links, etc) as to which ones you installed?
From memory, it was these:
maybe start a new thread re your 2006 which has different headlights to the OP's 2012 year... ... - .- -. Y. O. L. O. . |
