Home > Maintenance & Mods (L322) > Sidelight upgrades
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Sidelight upgrades
Anyone ever investigated an upgrade to the sidelights?
These pinpoints of light are pretty pathetic in today’s world.
 Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #611905 7th Nov 2021 3:49pm
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
+1 for this question. My Christmas lights are brighter than my sidelights. Looking for recommendations for replacements.
Post #611967 8th Nov 2021 2:40am
yes these fairy lights are pants...i tried upgrading them but my upgrade wasnt very successful,
Mr. Green
seriously though, you could use heat to prise the front lens off , buy some led rings, fit and wire up but this is a complicated and time consuming process..
i have seen company's on ebay doing this but its expensive..
personally i would convert the fogs into drls....i did this on all my previous FF's and its not that dificult.. ... - .- -.
Post #611975 8th Nov 2021 9:25am
Baltic Blue
Stan,
I am more impressed by your idea of adapting the two lower spotlamps as daylight driving lights.
Did you buy a kit ?
Post #611984 8th Nov 2021 10:00am
few ways of doing this Mike....simplest way is to replace the halogen bulb with a led bulb and cut the fog wiring and connect to a drl switch..
another method is to replace the OE bulb and housing with a drl light [ebay] and drl switch..
all mods require a bit of wire cutting and possible fog housing fettling..
here are my halo's fitted,
https://www.fullfatrr.com/forum/topic38570.html?highlight=drl
this thread shows how i fettled the lights,
https://www.fullfatrr.com/forum/topic33047.html?highlight=halos ... - .- -.
Post #611987 8th Nov 2021 10:21am
Baltic Blue
Thanks Stan,
I remember your Westie upgrade, and am very tempted, looked good.
Summer day project Thumbs Up , unless you fancy a day in Conwy Rolling with laughter
Cheers
Mike.
PS
My CarPlay unit is being delivered tomorrow so one job at a time.
Post #611990 8th Nov 2021 10:50am
re the carplay, i just bought an used one of ebay so it will be interesting to see what these things can do.. ... - .- -.
Post #611991 8th Nov 2021 10:54am
Gyre8
Soooo...... back to sidelight bulb replacements.....
Post #612017 8th Nov 2021 2:06pm
Baltic Blue
Apologies for causing a drift off topic.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #612022 8th Nov 2021 2:18pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
If you upgrade to DRL you should really wire them through a normally closed relay so that when the headlamps are on the DRL lights knock off.
This works in the opposite to a normal relay that switches the circuit on when power is applied. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #612023 8th Nov 2021 2:29pm
Gyre8
Thanks V8 Bob, but I don't want to upgrade to DRLs. I just want to try to seek recommendations for replacing the poor, yellow
sidelight bulbs with bulbs that are more in keeping (brightness-wise) with the rest of the front lights.
Post #612027 8th Nov 2021 2:38pm
dhallworth
Gyre8,
Your car has a different side light setup to the one in the original post. The bulbs in yours are easily changeable and can be swapped to LED's very easily. I did mine a few months ago.
Seeing as my lights are always on Auto the sidelights never do much anyway so it was more to get rid of the yellow looking light that made me change mine.
Post #612028 8th Nov 2021 2:47pm
Gyre8
Ah. Thanks dhallworth. Do your LEDs give canbus errors? And can you give any info (product, links, etc) as to which ones you installed?
Cheers.
Post #612036 8th Nov 2021 3:56pm
dhallworth
From memory, it was these:
https://www.ebay.co.uk/itm/164393297301
Post #612038 8th Nov 2021 4:13pm
maybe start a new thread re your 2006 which has different headlights to the OP's 2012 year... ... - .- -.
Post #612039 8th Nov 2021 4:14pm
