Home > Maintenance & Mods (L322) > Rear wheel bearing 2011 tdv8
DrRob
Have a strange wind tunnel like noise from drivers side....
Diagnosed to rear drivers wheel bearing. Done via a stethoscope on each hub carrier whilst car dangling just off the ground on the scissor lift and in Drive..
Advanced Factors do a £25 kit with a FAG bearing...
Will report back Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #610678 27th Oct 2021 8:17pm
DrRob
Wasn't the wheel bearing. Odd.
New tyres going on soon. I bloody hope that fixes it. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #612079 8th Nov 2021 9:30pm
lets hope its an easy fix Rob...frustrating when its not obvious.. ... - .- -.
Post #612089 8th Nov 2021 10:11pm
dhallworth
My SC has a noise similar to this but it comes on suddenly at 60mph and goes as soon as you get to 71mph.
I’ve gotten that fed up with it I’ve got a front diff and 4 wheel bearings to swap out when I get time. I did have a rear diff but it turned out to be the wrong one so has been returned.
Hopefully new tyres fix yours.
Post #612091 8th Nov 2021 10:56pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Dr Rob, are you sure it’s not one of the bushes? I had a similar issue on the SC and I replaced the bearing but it didn’t get rid of the drone but then I replaced the top rose and bottom bush and it’s been fine since.
Regards
John
Post #612104 9th Nov 2021 12:14am
DrRob
Thanks for all the pointers.....will get there in the end! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #612114 9th Nov 2021 8:29am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Someone will no doubt correct me if I'm srong, but I recall early L322's being fitted with, I think, Goodyear Wrangler tyres and it was found that when part worn they generated a noise not unlike a worn wheel bearing. In the US I believe tyres were often replaced under warranty for this issue (not in the UK obviously!). in 2007 I had a 2003 M62 engined L322 with Wranglers and it did indeed make a noise like worn wheel bearings on part worn tyres. By this time LR were fitting Pirelli Scorpion as OE, so I replaced with these and no more issues. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #612115 9th Nov 2021 9:14am
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
I sometimes have a similar noise. Turn on air recirculating and goes away.
Post #612118 9th Nov 2021 9:59am
DrRob
It's coming from outside and not through the vents. I've heard a whistling noise before through vents though. Totally different. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #612119 9th Nov 2021 10:25am
DrRob
Regards
John
John
Which bits did you replace?
https://www.advancedfactors.co.uk/rear-hub--carrier-289-c.asp
Parts ending "260" and "644"?
Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #612202 10th Nov 2021 12:51pm
tb10
Dr Rob,
Yes, both 260 and 644.
You should be fine with AF parts as there is a cautionary tale here, specifically with the rose joint #260
https://www.fullfatrr.com/forum/topic61066.html
No issue with #644 as it has the circlip #010 retaining it.
Also, just check your tyres first. Just try swapping the wheels round and then drive the car to see if there isn't any internal issue with the integrity. I say this as I note that there are a number of Full Fat's that fail, or have an advisory, on their MOT's relating to a bulge in the tyre. Just a thought.
regards
John
Post #612206 10th Nov 2021 1:16pm
AutoB2018
Have you tried adjusting the tailgate spoiler? I had to remove mine to fix wiper arm, refitted and had whistling noise after 60mph, adjusted to make sure even gaps on either side and hey presto no noise. Worth a try ?
Post #612309 11th Nov 2021 3:05pm
DrRob
Noise is there from virtually 10mph upwards.
New tyres soon anyway. If that doesn't cure it then look elsewhere.... Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #612314 11th Nov 2021 3:53pm
DrRob
Disc is a tad too hot so new caliper time. Could even be source of noise...wasn't the bearing. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #612516 13th Nov 2021 5:58pm
DrRob
Callipers were fine. Pads were poor so changed for TRW ones.
Noise still present
New tyres soon Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #613820 25th Nov 2021 8:04pm
