|  | Home > Maintenance & Mods (L405) > Corrosion issues? |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885    |
 Being all aluminium, corrosion shouldn't be a problem, right?
|  10th Nov 2021 7:50pm |
| Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 118      | Wow, thats not good.
|  10th Nov 2021 8:01pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | That’s a bit scary. One of the advantages of going from L322 to L405 was to not worry too much about rust….
|  10th Nov 2021 8:05pm |
| caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1176      | With all the water , salt and   | ||
|  10th Nov 2021 8:08pm |
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1211      | That, looks like electrolysis to me? dissimilar metals together with saltwater create electrolysis? | ||
|  11th Nov 2021 8:35am |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885    | Correct. Big steel spreader plate on top of each subframe mount, in direct contact with the body... | ||
|  11th Nov 2021 12:43pm |
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1211      | If the body has some flex between the mating surfaces then the water will capillary between to start it off? boats, outboard motors,l that is in contact with salty water has a sacrificial anode.
|  11th Nov 2021 1:40pm |
| Johnh Member Since: 07 Nov 2011 Location: Rugby Posts: 44      | Even painting the bracket would help, on the to do list when purchasing a l405 | ||
|  11th Nov 2021 1:45pm |
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464      |
 Other manufacturers cope on cheaper cars than a RR, why dont RR do a bit of R&D into corrosion protection????? BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 | ||
|  11th Nov 2021 4:37pm |
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1432      | What a depressing thread.  My 2017 405 has had various bolts around the headlight mounts replaced due to galvanic corrosion (visible white furring) and one on the lower tailgate under the flap at the back of the tailgate (just rust there).  The dealers said they were well used to replacing the bolts around the headlights.  Scotland will be particularly bad for corrosion with so much salt on the roads and lots of wet weather.
|  12th Nov 2021 12:14pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | That's scary. Especially given that it's above the subframe and can't be easily inspected.
|  12th Nov 2021 2:09pm |
| Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 494      | Definitely dissimilar corrosion going on there.  Moisture forms the electrolyte and the fizzing begins.  Sad to see a poor choice of materials there and a lack of separation between the steel and aluminium. 2017 Range Rover Vogue V6 Diesel
|  12th Nov 2021 5:51pm |
| 154JON Member Since: 31 Mar 2019 Location: Essex Posts: 133      | I think the problen in this thread on the L405 https://www.fullfatrr.com/forum/topic55957.html which i have suffered at great expense is down to two dissimilar metals and galvanic corrosion occurring or it might just be a bad batch of knuckles. | ||
|  12th Nov 2021 6:17pm |
| WaterloggedFFRR Member Since: 22 Feb 2022 Location: Louisiana Posts: 6      | Lost my 2014 ATB to corrosion. 70k miles.  Over $30k in damage. Probably would have been over $40k had I done the repairs. Rusted sunroof drain flooded the vehicle interior.
|  22nd Feb 2022 12:31pm |
| Posting Rules
 on our roads its not surprising really.
