Home > Maintenance & Mods (L405) > Corrosion issues?
Mikey
Corrosion issues?
Being all aluminium, corrosion shouldn't be a problem, right?
We have a 2014 SDV8 in currently. It was actually in a few weeks ago for a service, on the service we noted leaking rear ARC pipes and leaking rear HVAC pipes. Nothing unusual there, it's 7 years old with nearly 100k miles
So, it was back in today for the work to be carried out. Subframe down without any dramas
Obligatory photos for Faceache
But look closer at the last picture...
That is quite frightening on a £100,000 car of that age. The other side was better, but still holed. Thankfully not structural, but strictly speaking, within 30cm of a suspension mount, and would be an MOT failure. And mostly hidden underneath the steel bracket from the front subframe mount...
Post #612241 10th Nov 2021 7:50pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Wow, thats not good.
Has 'mot welding' begun to encompass aluminium yet? Laughing
Chris
Post #612244 10th Nov 2021 8:01pm
mjdronfield
That’s a bit scary. One of the advantages of going from L322 to L405 was to not worry too much about rust….
Fffffff
Why can’t they use better steel… same on the last L322…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #612246 10th Nov 2021 8:05pm
caymanblack
With all the water , salt and Censored on our roads its not surprising really. Crying or Very sad
Post #612247 10th Nov 2021 8:08pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
That, looks like electrolysis to me? dissimilar metals together with saltwater create electrolysis?
Post #612273 11th Nov 2021 8:35am
Mikey
Correct. Big steel spreader plate on top of each subframe mount, in direct contact with the body...
Post #612294 11th Nov 2021 12:43pm
JCW
Assume a thin foam gasket would break the contact between the two dissimilar metals and stop the galvanic corrosion occurring?
Would have thought LR would be well up to speed on this given all their experience with the original Defender… Whistle
Post #612301 11th Nov 2021 1:23pm
Tinman
If the body has some flex between the mating surfaces then the water will capillary between to start it off? boats, outboard motors,l that is in contact with salty water has a sacrificial anode.
Which is old knowledge? I would have thought JLR would know this?
Post #612304 11th Nov 2021 1:40pm
Johnh
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Even painting the bracket would help, on the to do list when purchasing a l405
Post #612306 11th Nov 2021 1:45pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Other manufacturers cope on cheaper cars than a RR, why dont RR do a bit of R&D into corrosion protection????? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #612322 11th Nov 2021 4:37pm
CS
What a depressing thread. My 2017 405 has had various bolts around the headlight mounts replaced due to galvanic corrosion (visible white furring) and one on the lower tailgate under the flap at the back of the tailgate (just rust there). The dealers said they were well used to replacing the bolts around the headlights. Scotland will be particularly bad for corrosion with so much salt on the roads and lots of wet weather.
Incidentally the dealers said before they installed the new bolts they coated them with some tarry substance to reduce the contact between the different metals, adding it was disappointing LR did not do that. So unlikely LR do much on the areas highlighted by Mikey.
I got the impression that LR had instructed dealers not to look for this sort of thing, but just to respond when customers found it. Not helpful. LR made quite an effort to rustproof the P38, given the bad PR generated by rusty Classics, but that seems to have been abandoned with effect from the 322, presumably on the basis they would build for a global market and only a small proportion of production would be used in places like Scotland. I moved from 322 to 405 because I was fed up with having to have rust treated every year (from 2yo) , but while the 405 does not show corrosion in the same way, it may be worse in some respects because it is causing structural problems one can't readily see.
Mikey, if I want to ask the dealers to check on this on my car what is the best description of the place to look? Only Range Rovers since 1988
Post #612406 12th Nov 2021 12:14pm
dhallworth
That's scary. Especially given that it's above the subframe and can't be easily inspected.
Could that lead to the rear subframe becoming insecure seeing as that's a subframe mounting bolt?
I take it without removing the bolts and dropping the subframe there's no way to spot anything on this?
Post #612418 12th Nov 2021 2:09pm
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Definitely dissimilar corrosion going on there. Moisture forms the electrolyte and the fizzing begins. Sad to see a poor choice of materials there and a lack of separation between the steel and aluminium. 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #612439 12th Nov 2021 5:51pm
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
I think the problen in this thread on the L405 https://www.fullfatrr.com/forum/topic55957.html which i have suffered at great expense is down to two dissimilar metals and galvanic corrosion occurring or it might just be a bad batch of knuckles.
Post #612441 12th Nov 2021 6:17pm
WaterloggedFFRR
United States 2015 Range Rover Autobiography 5.0 SC V8 Mariana Black
Lost my 2014 ATB to corrosion. 70k miles. Over $30k in damage. Probably would have been over $40k had I done the repairs. Rusted sunroof drain flooded the vehicle interior.
Post #624408 22nd Feb 2022 12:31pm
