![]() | Home > My Range Rover > And here it is… L322 Overland Build |
2010BlackL322 Member Since: 30 Oct 2021 Location: London Posts: 120 ![]() ![]() ![]() |
2010 L322 Range Rover Autobiography Black. 135K Miles
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8749 ![]() ![]() ![]() |
You'll probably find the wind deflectors are there as the black window surrounds start rusting from the top down and the deflectors cover it up... |
The window surrounds are fine, checked under them when I peeled one back, but you never know what’s under them.
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 287 ![]() ![]() |
If you don’t find a suitable roof rack I saved this from the Disco3 forum.
I have them on the Defender, which is far worse with rain pouring in off the gutter, but they look terrible on the RR |
Thanks, I have a cargobear on the defender and love it, they make a rack for the Disco 3/4 but I’d have to check the width dimensions and the mount brackets for the roof rails / factory mounts, and how they match up to the rack. As with anything, can be done, just depends on the time, effort and probably £ to make it all fit. But, looking like this one and avoid the hassles https://www.landroverpassion.com/en/produc...over-l322/ Thanks ![]() https://youtu.be/UHBbLWZXw4A |
Andy2986 Member Since: 26 May 2019 Location: Suffolk Posts: 117 ![]() ![]() ![]() |
Ive had a drawer made for the back of mine ( I use it as a gun safe ) It was made to measure and cost around £800. Will dig out the address if it’s the sort of thing you want. I’m going to be using the company again to add to the drawer system in my disco 1.
1998 D1 300tdi 1971 2 door Classic |
That looks like it would work, how have you attached it to the load space floor?
It’s a guy on eBay “metallicsuk “. I dealt with him through eBay messenger.
Thanks Andy, Will contact him
Good news, after destroying an old plastic locality card, the wind deflectors are off, and there is zero rust underneath. ![]() ![]() https://youtu.be/UHBbLWZXw4A |
As I mentioned in my initial post, the tyres where installed white walls out, yuck, so they turned them around, and I think you’ll agree, it looks much better that way.
A full weekend to getting to grips with the L322.
3 weeks in, the plastic trims has been removed, almost all of it, grille, vents etc were cracked, missing tabs, paint chipped, or the fake chrome peeling off, all replaced. Fog lights replaced with smoked LED’s, the trim that holds them in, rattle canned gloss black. The high level brake light was cracked, only 4 random LED”s working, replaced with a smoked version. The stealth look not for some, traditionalists will be shouting “heretic” at your screens, but this for me is how I want it, and this is not, or won’t be a curb princess. This is going to do what it was built to do.
