Home > Off Topic > Help! Knott Trailer Brake Shoes Replacement
garyRR
I've replaced the wheel bearings, seal and brake shoes on my trailer (200mm Knott) however, I was expecting the drum to slide straight back on but, it's getting fouled by the new shoes.
I have changed the adjuster to it's minimum setting. Do the adjuster tabs need removing with the later designed shoes? I noticed a video on YouTube where the guy didn't have them.
Here's some photos. Please can someone advise (you're viewing left side of trailer)?
 2015 Range Rover Autobiography 4.4 SDV8
Post #612692 15th Nov 2021 10:27am
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
HI
What does the metal tab each side of the adjuster holder do, i have seen a lott of knott brakes but i have never seen the tab as you call it each side of the adjuster. Also compair the new left brake shoe to the old one and make shore the brake shoe is sitting in the silver holder the same as the old one as it can come unseated which will make it sit out further stopping the drum sliding on.
Post #612696 15th Nov 2021 11:49am
garyRR
I have no idea what the adjustment tabs do. They are removable.
I found a photo of the before:
You can see the brake cable holder is the other way around but, I thought they were supposed to have the 'arrow' facing forward. BUT, this was the other left brake, with it with the arrow facing forward:
You can see the brake shoe design has been updated vs my old ones. The lower spring now sits below and the retaining spring is now a 'press in place', whereas the old was a twist type rivet. 2015 Range Rover Autobiography 4.4 SDV8
Post #612698 15th Nov 2021 11:55am
154JON
If thats the same wheel you have put the expander round the wrong way.
Post #612701 15th Nov 2021 12:14pm
garyRR
The picture with the blue axle is the front left axle. The other picture is the rear left axle (twin axle trailer).
One of the drums had the expander hinge facing forwards and the other had it facing backwards... Despite both being on the left side of the trailer. 2015 Range Rover Autobiography 4.4 SDV8
Post #612704 15th Nov 2021 12:36pm
154JON
Did a dealer say they would fit or did you just buy same size later shoes.
Post #612705 15th Nov 2021 12:53pm
