Home > Technical (L322) > have i got all the sat nav bits
pretlove
will the gps antenna from a rrs fit on the mk3 system? "RANGEISM WILL NOT BE TOLERATED"
Post #61279 22nd Apr 2011 12:22pm
i should think so, any gps antenna should work as long as you have the correct plug..
this is the type i used on an after market sat nav i installed ..
http://cgi.ebay.co.uk/GPS-Antenna-Aerial-5...4cf142ca2a ... - .- -.
Post #61280 22nd Apr 2011 1:27pm
pretlove
thanks scarey ...have you got any pics of your install also do you know if this is the amp on my hse
Post #61281 22nd Apr 2011 2:33pm
aint got no pics of mine ...i tend to stay away from that compartment as i would probably start taking things out and i wont be able to put it back together....mines a touch screen setup so it'll be different?.. ... - .- -.
Post #61282 22nd Apr 2011 3:04pm
SteveMFr
Site Sponsor
I have to call on the harness...GBP 175ish IIRC
GPS antenna GBP20
Yes, that is your audio amp - you have the mid-line version amp and, in theory, it should work just fine with the plug n play satnav harness. 'In theory' only because you should never say never Very Happy
The plug on the back of the present radio/cd player runs the speaker leads directly to the amp - which is the same thing that the new unit will do via the new harness. The amp sends a signal on the i-bus telling the radio unit that it is there and the radio switches to pre-amp level output. In the base audio system the radio unit does all of the amplification as well.
I'll let you know as soon as I can.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #61330 23rd Apr 2011 4:07pm
stevenA
2002 Range Rover Vogue Td6 Zermatt Silver
Sorry to disagree Steve - the radio (BM54) functions the same in this config as if connected directly to speakers and does not give a fixed level output.
There are two BM54 configs - constant level (fixed) for the DSP and amplified (Hi level) for this amp or direct speaker. This amp is not connected to the iBus.
I know as I have just put a BMW version in mine to solve my incessant audio problems Twisted Evil
Post #61939 28th Apr 2011 6:48pm
SteveMFr
Site Sponsor
I'll take your word on it, Steve. You are def qualified as a BM54/amp expert. That'll teach me to open my yap too quickly. Laughing
Either way the plug n play harness will (should) work.
BTW, would you happen to know if BM54's w/bad internal amplifier channels will still work with DSP?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #62019 28th Apr 2011 9:42pm
pretlove
thanks steve and steven Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #62030 28th Apr 2011 10:45pm
stevenA
Sorry Steve, I do not know - but guess the answer would be no, as even the fixed level goes through the output stage (the fixed level is still amplified).
However, as in this configuartion, only two of the four output stages are used, depending on which chips have failed, you may be able to work around
Post #62270 1st May 2011 8:03am
