![]() | Home > Technical (L322) > 2003 4.4 zf5hp24 Gearbox just been serviced, Red oil used ? |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
Hi all,
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3345 ![]() ![]() ![]() |
I helped a friend change the gear oil in his when it needed doing. He used LT71141 and I’m 99.9% sure it was straw coloured. If someone has put red oil in yours then it sounds like it’s the wrong oil.
updated with part invoice. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
JWS3309 and LT71141 are two different fluids.
https://www.buycarparts.co.uk/mannol/15768409
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1051 ![]() ![]() |
This is what I used, it is straw coloured NOT red
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
They are one of the best in the business for LR transmissions so I doubt it very much they put the wrong fluid in.
Hi, I totally agree which I why I wanted to ask on here first as not said bad word they did the job and they are well recommended just put me back a little when reading the red fluid was used. as when doing my research, everyone says fluid which is rated Dexron III and LT71141 is not really the correct to use. Of course I am no expert which is why I am seeking advice here. hoping RRphil will jump in and comment. The gearbox was rebuilt under Warrenty 09/2018 @ just over 111k, by another garage. reason for recent work was leaking gearbox oil pan, and I believe oil was low in gearbox and of course this could be a non issue, but rather know now instead having issues and in back my head thinking if its the fluid. 2003 Range Rover 4.4 Litre V8 - Adriatic blue 2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html |
Billie Member Since: 12 Oct 2020 Location: south-west Posts: 49 ![]() ![]() ![]() |
Call and chat to them I would |
