![]() | Home > Technical (L322) > EGR’s - Throttle Bodies - Turbo’s : And how they work. |
briangunn Member Since: 19 May 2019 Location: London Posts: 56 ![]() ![]() ![]() |
There is no waste gate - the turbo is variable vane. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3297 ![]() ![]() ![]() |
The waste gate is only open under boost ( overboost) so won't be a bypass route around a seized turbo. Can you pull the intake hose of the turbo inlet and see if you can spin the blades? 2012 TDV8 Vogue (L322) |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1850 ![]() ![]() |
It's 99% a failed LH turbo Until you remove the downpipe, or intake pipe, your not going to know Same as I said on your other thread... |
Kevhdkent Member Since: 27 Oct 2021 Location: Kent Posts: 69 ![]() ![]() |
Thanks Mikey, that’s what I wanted to know.
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 197 ![]() ![]() ![]() |
apologies for resurrecting an old thread but like Kevhdkent all those years ago , I'm trying to get my head around EGR valve operation.
