Home > Technical (L322) > EGR’s - Throttle Bodies - Turbo’s : And how they work.
Kevhdkent
Re: EGR’s - Throttle Bodies - Turbo’s : And how they wor
[quote="GraemeS"][quote="Kevhdkent"]
Caesium wrote:
Kevhdkent wrote:
The purpose of this exercise is I’m trying to understand the conditions that caused a critical drop in power while motoring at speed, reducing revs to 500rpm but without stalling the motor. Then complete non-starter, UNTIL the EGR to intake manifolds were disconnected ?
Could the EGR’s fail to open at speed ? Could this cause both lack of power at 60mph, and then refusal to start ?
Starting only occurring when clean air is allowed direct into the manifold ?
Disconnecting the EGR intakes gave exhaust gas somewhere to go which then allowed the engine to fire, indicating that the exhaust was effectively entirely blocked indicating a stuck turbo, nothing to do with EGRs.
This is actually the theory I am trying to test. However, I have not been able to find a schematic that illustrates the full air/turbo/exhaust flow. I am lead to believe that there is a 3rd route available for exhaust gases beyond recycling via the EGR or flowing thru the turbo. That being a waste gate, in which case a disfuctional turbo would not cripple the motor ?
I’ve plainly got a (massive) hole I my knowledge, but everyday’s a school day, so what am I missing ?
Post #613100 18th Nov 2021 10:22pm
briangunn
United Kingdom 2010 Range Rover Vogue SE TDV8 Buckingham Blue
There is no waste gate - the turbo is variable vane.
Post #613101 18th Nov 2021 10:24pm
JayGee
The waste gate is only open under boost ( overboost) so won't be a bypass route around a seized turbo. Can you pull the intake hose of the turbo inlet and see if you can spin the blades? 2012 TDV8 Vogue (L322)
Post #613102 18th Nov 2021 10:28pm
Mikey
It's 99% a failed LH turbo
Until you remove the downpipe, or intake pipe, your not going to know
Same as I said on your other thread...
Post #613114 18th Nov 2021 11:16pm
Kevhdkent
Thanks Mikey, that’s what I wanted to know.
The purpose of this thread and the reason I started a separate one is that I want to understand the reasoning and mechanics behind the issue rather than simply accepting (very welcome) advice.
I guess that’s why most people are on this part of the forum instead of just giving their car straight to a dealer.
I’m just in the early stages with a very low knowledge base !
Post #613127 19th Nov 2021 7:58am
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
apologies for resurrecting an old thread but like Kevhdkent all those years ago , I'm trying to get my head around EGR valve operation.
I have an L405 TDV6 mono turbo and having gone through the DPF regen saga I seem to have regens off to a fine art using the famous Kot kit. However looking at the EGR valves, demanded and actual position the B valve does more or less what it's supposed to but the A one is all over the place . It would seem that the valves should be 10% open at the start of a regen but the A valve goes straight to 90% and most of the time it indicates a 100% error. I've double checked the numbers using Icarsoft and get the same readings. Everything seems to work as it should and no alarms.
I mentioned it to my local indie and he seemed to think there was nothing to worry about Confused
Is my understanding of what they should do correct, or should I be worried?
Thanks for looking.
Post #709379 16th Jan 2025 9:13pm
