Home > Technical (L322) > Front airspring top cap forgotten how to get it off |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 80 |
Good evening Nick when I replaced mine recently, with complete new ones, I decided to strip the old ones just to see how they went together.
17th Nov 2021 6:42pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
They use STC 50554, which apparently is Loctite 648
17th Nov 2021 7:03pm |
nick4275 Member Since: 28 Sep 2018 Location: Bewdley Posts: 51 |
Thanks both,
17th Nov 2021 8:06pm |
I assume we are all talking about this btw, the cover over it is plastic but they just pop off.
17th Nov 2021 8:50pm |
Yes, that's the one !
19th Nov 2021 4:52pm |
It’s threaded Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
19th Nov 2021 5:01pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3194 |
That's true for practically all of them but I had both fronts done with complete struts a couple of months ago. When I had the second one done I got an Arnott strut and it came with the damper already fitted and all the clips for cables etc as well. The first one didn't have it and it was necessary to change it over. It was finally removed when the strut was off the car. One of the difficulties is when you try to remove it in situ everything turns. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
19th Nov 2021 5:20pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2982 |
I’ve spent ages battling with one of these today!
19th Nov 2021 11:24pm |
Getting them to 250 to break the hold is the hard part IMO.. I think I used a 2KW hot air gun and a laser temperature gun, I couldn’t believe it just screwed off (with welders gloves) when it got up to temperature.
20th Nov 2021 10:35am |
I'm still at it !!
24th Nov 2021 6:37pm |
Looks like it’s probably SEB500490:
24th Nov 2021 9:45pm |
Yikes!
24th Nov 2021 9:53pm |
Double yikes !!
25th Nov 2021 4:22pm |
If you've got the top of the strut off, turn the oven up as hot as it'll go, bung it in it for 20 mins to let it get hot then remove it.
25th Nov 2021 4:26pm |
